Digital Everywhere FloppyDTV | SatelliteGuys.US
49studebaker
71
Can this card be used to pick up free dvb and dvb-s2 channels in the United States?
FloppyDTV S2
- Antenna Connector: F-Type 75 Ohm
- Input Frequency Range: 950-2150MHz
- Supported Modulation: 8PSK/QPSK (DVB-S2), QPSK (DVB-S)
- LNB Supply, 13/18V, 22KHz tone, max. 400mA
- DiseqC: 1.0, 1.1, 1.2 (depending on used Software)
digital everywhere - FloppyDTV S2
It's recommend dvb/dvb-s2 tuner for mediaPortal pvr:
http://www.team-mediaportal.com/recommended_tv_cards/dvb_cards/firedtv/floppydtv.html
Those specs match a typical receiver / PCI adapter specs. You shouldn't have trouble with the right LNB & dish. It really is more of a software question though. E.g. Does that card have good drivers and software support?
Problems installing a sonicview 8000hd
RTN Programs listed on RTNVILLE have changed
