Diffrences between 622 and 942. | SatelliteGuys.US
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,751
29,575
Newington, CT
What's new on ViP622 DVR compared to DISH Player-DVR 942:
· MPEG-4
· Composite A/V & S-Video for TV1
· Ethernet port (for future use)
o Don't connect the phone line to this port!
· Agile output can display both TV1 & TV2 programming
o TV1 UHF Pro remote control provides receiver operation from a distance.
· Combined Themes & Search screen
· DISH On Demand
o Put receiver in standby
o Content is 4x3 with no stretch choice
· TV1 Audio Sync
o Make selection based on VIDEO display, no matter which audio connection is used.
· HD Enabling
o See status in Sys Info
· Most iTV Apps expected at launch, and others will launch soon
· Two ViP622 DVR Remotes (one IR, one UHF Pro)
o Four colored DVR buttons
- For future iTV use
o White Recover button
o Easy Limited Mode programming
· Recommendation for SD TV1
o If TV1 is connected using SD outputs, use 4x3 #2.
- Maintains 16x9 aspect ratio on HD channels (bars on top and bottom)
- SD channels won't have Format options
o If 16x9, "Normal" format is tall and thin on HD channels
Does all that mean you can no longer "stretch" 4:3 SD programming to fit 16:9 on a 622? I've never used this a whole lot, but seems like a big switch from previous HD receivers if true.
Can anyone elaborate on these changes:
Specifically, do any of these changes mean that when outputing an HD channel or an SD channel via component or HDMI at 720 or 1080, the 5 stretch modes available on a 942 or 811 will not be available with the 622?
My TV won't do it with HDMI or component.
And I have the same burn-in issue with my CRT RP. But if it does support the non-stretched graybar 4:3 mode, then I would be okay.
Otherwise, I'm going to have to connect the s-video and then watch all SD 4:3 via s-video where I can employ the TV's stretch modes.
Anyone Have A 622 Yet???
211 ethernet port usage yet?
