DG380B Wanted | SatelliteGuys.US
DG380B Wanted
ESA1178
179
Sacramento, CA USA
Since Sadoun has no ETA on the DG380B, I'm hoping that someone out there might have an unopened motor.
Perhaps, realizing that they ordered the wrong one etc.
In either case, please pm me if you have one for sale...
Thanks!
Mark
Thanks for the info Brian.
Sadoun quit replying to my emails regarding a 42 mm tube for my DG380 mover after they moved to TX.
I understand that the DG380b is not on order, but the "b" tube will be stocked. Sorry, didn't ask about a delivery date.
You didn't tell us about your dish.
Unless it' a tank , I'd go with the Stab HH90.
(and if it IS a tank, I wouldn't go with the B ). :)
When we discussed motors recently, someone found it for around $69, or so.
I think Stab invented that technology. ;)
That's a good point. The type of dish is important, and I thought of something else. Everyone says the max. limit on those "B" motors is a 1 meter dish, but if your mount type allows for it, and you plan on abusing your dish with projects such as the mini-BUD (like I did!) with the extra weight from the scalar and C-band LNBF, then that makes the larger tube a better choice. I had to get longer bolts from the hardware store to make it work with my 90 cm dish, but I'm pleased with the results. That could have been the real reason my 9120b stressed out on me :)
My receiver doesn't list AMC 9. What do I do?
Add sound to Huntington Pier Live Cam
