Indeed. You can watch NASA TV in SD or HD or (for some programming) UHD.Perhaps it is because Dish chooses the SD version? NASATV streamed from their website is in HD. So NASA HD does exist.
Perhaps Joseph meant that Dish is broadcasting the SD NASA feed in anamorphic widescreen. N.B. I didn't check on that.A channel is only what the transmitter allows it to be, that is to say broadcasting an SD channel as HD is not bandwidth wise and I don't think Dish would waste bandwidth that way.
Good points. Is there a reason HD channels seem to not be as loud in audio compared to the SD channels if there are both versions available?A channel is only what the transmitter allows it to be, that is to say broadcasting an SD channel as HD is not bandwidth wise and I don't think Dish would waste bandwidth that way.
Technically there is no such thing as an HD or an SD channel on the satellite, it is all predicated on what the bandwidth requirement of the program is and even that is adjusted on the fly to reduce bandwidth if the frames or even an individual pixel is repeated. This is accomplished by the compression hardware, so an SD program put on a so-called HD "channel" is not the way the system works.
A certain amount of data is sent to the satellite, compressed and optimized to its best potential. It is retransmitted unchanged to your dish and receiver and the receiver interprets that data as either HD or SD content and sends that to your display.
The only difference may be whether the signal is compressed by MPEG2 or MPEG4 compression algorithms of which MPEG4 is about 2X better then MPEG2 (IIRC). That is why Dish is eliminating MPEG2. SD and HD are only a matter of how much bandwidth the data requires.
Another possibility is that the program originator converts a 480i program to 1080i, but even there the satellite compression algorithms would compress it to a bandwidth similar to whatever it would have been even if it was still 480i.
YES, the HD channels are dolby audio and most sd channels are PCM audio.Good points. Is there a reason HD channels seem to not be as loud in audio compared to the SD channels if there are both versions available?
Did you read that contract? Especially the part that say programming is subject to change without notice?Meg2, Schmeg2. The bottom line for me is that while I was not actively watching some channels last spring, Dish dropped my SD recording programming without notification, causing me to miss much of the season for many of my favorite programs. I had hoped to capture them this summer via reruns, but they didn't repeat in any format. If I had the time to document what I missed, I'd lodge a formal complaint and insist on a refund for non-delivery of contracted content.
Maybe you need to go back to a OTA antenna and a VCRI probably didn't read it, but nevertheless I did not receive the mainstream (ABCCBSNBCETC) programming I paid for.
Given that they have the technology to erase my DVR without my consent, couldn't they at least have notified me and/or automatically switched my SD recording preferences to HD when they dropped SD?
It would fit your forum name better.It may be more reliable.
Well instead of Spectrum, why not try YouTube TV then, their cloud DVR will always record, even if there is a sunspot or tree root or seasonal temperature change problems.I don't care who broadcasts what shows in what format, down the street or in technospace*, or how many pimples I can see on somebody's face on my boob toobs. All I ask is that Dish (and Spectrum) provides me with the mainstream TV shows I pay them for. One reason I have two TV providers is so I can watch a show on one when the other plays games such as contact disputes or format changes, or has satellite or cable or sunspot or tree root or seasonal temperature change problems, etc.
They don't. I was told switching to SD to HD costs more money than the services want to spend. Even some channels that are in HD, they cost more for Dish to carry them. One is Disney. That is by some of their channels are still in SD. The Super Stations probably will never be offered in HD as so few still have them and I doubt Dish will want to use the band width.Well isn't it up to the TV Channel's/Stations themselves to broadcast in HD, I don't think all Channels broadcast in HD.
No offense...but Dish has been telling customers that certain models of equipment and SD was going to be going away...and to prepare for it....for YEARS now.I probably didn't read it, but nevertheless I did not receive the mainstream (ABCCBSNBCETC) programming I paid for.
Limited time offer
