Stargaze,
Question#
1. No....4562
2 No... starts at 252
CF no lock on channel 107. First lock is on channel 120.
3 W5 didn't show up.
Have music on channels 825-829. Do have DCII lock on most the Digital channels say from 120-369. What is happening in my receiver is not like anything others have reported. Numbers are all out of sink with everyone else.
My EMM Provider shows 4160. My rehits started at 0 and about an hour ago showed 7 hits. CF doesn't work and X4 seems to be only partially working. Music only.
What do you think about that?
RE: Battery replacement! It's a piece of cake! I'm not an electronics guy nor can I solder worth a crap but I changed mine out in the 920 and also in the DC2 module so it can't be but so difficult and BTW, those batteries I removed were STILL GOOD!
I got the batteries for mine at the local ratshack.
i doubt x4 will update if it is programmed in your selected sats (mine wouldnt). im also inclined to think that your missing moto's maps and that your channel count is going to vary(its only supposition) but could prove that there are more maps than what we think are there if you do get a channel count of 4782. i wonder if anyone has master reset for the 7-step and only mapped on x4/w5 (im so tempted to master reset one of my 4d's). i also think some of the issues people are having are setup issues rather than process issues. for instance (no disrespect intended stargaze), i lock 1430.000 as Horizontal on my 922 and 905 while lyngsat and stargaze have it as Vertical. this discrepancy has been discussed before with the conclusion that the 4d units have a reversed polarity from dvb stb's. i for one need to use the rotated 90 option in my dish set up for the 4d's to lock.
crackt out,.
my emm was 4160 after my auth reset but now its showing both 4096, 4160, 2
Did anyone who hasn't converted to 4160 and still has "extended" programming get shut down this weekend?
Cheers
I pulled the plug on the 922 and let it reboot, the ZK and FP channels returned. GB-410 is still OC though. I don't think anything can be done about that now.
GB-410 on my 922 went OC last week.
GB-410 on my 922 went OC last week. Since the maps were pulled from G1-3, there was no way to get a hit which fixed the OC problem before. So I decided to try the 66780 to see if it made any difference. My EMM changed to 0. I soon discovered that I couldn't receive any ZK or FP channels. However, when I pulled the plug on the 922 and let it reboot, the ZK and FP channels returned. GB-410 is still OC though. I don't think anything can be done about that now.
would you conclude this is going to be everyones fate sooner or later...where chs like GB 410 will go OC eventually?
I disconnected my LNB on the 26th of Dec & watched FTA until Jan 5th. When I went to W1, the Denver 8 were still in tact. Channels 500-507.Are these Dever stations on TP 500 and above? All get is subscripition required..
4096 is still up Monday night.
Is it sending out hits or anything? I've been all over the place today for considerable amounts of time..C4, C3, G0. G1, etc. My trip counter still says 0.
Limited time offer
