Cuba Vision on Hispasat 1D @ 30 | SatelliteGuys.US
kelleyga
320
11884 V, Do I need a universal LNB or a Regular LNB?
I have a viewsat receiver and a 1 meter dish
If you have no obstructions in your LOS, you should be able to get that with a Standard Linear lnbf. I know I do, any TP above 11700 should work with a standard lnbf. Any below 11700 would you would need a Universal lnbf.
standard LNB works just fine here in Minnesota for Hispasat
Now the Cubavision on 58W you DO need a Universal
Hi kelleyga,
If I remember correctly, you are receiving signals in Costa Rica. Is that correct?
If so, it may be too low in the sky for you to get Hispasat. :(
EDIT: Ok, I take that back. Looks like the eleavtion is about 20 degrees. It will depend on if you are to the west of one of those mountains I see there. :)
cant get G25
Program Guide
