Is the CS7000 and the CS7100 firmware the same for factory. I just got a 7000 but has third party software on it. I would like to go back to the latest factory but can not find anything but the CS7100 software.
Chuck
No
Chuck
Yes no problem, but I don't know the protocol for this site and software attachments, If I upload then with my next post will I be breaking any rules?Could I talk you into letting me grab them from you. At least that would be a step closer to getting it back to factory
Chuck
factory software we have no issues with. I've posted factory stuff here for years
Its when folks post stuff that is new hackware then there are issues.
Oh.!. -the CS7000 has a USB port so he can just download it and plug the usb item into the reciever to update the software
Coolsat 4000 Plus - NullYou will need a working serial port (or maybe a USB to serial converter).
You'll also need a serial cable, but I don't know if it will need to be straight-through, or a crossover type.
The crossover cable swaps serial input and serial output compared to straight through cable.
Limited time offer
