Craig T.V remote | SatelliteGuys.US
Craig T.V remote
richware1
4
Clinton, Maine
Does anyone have a remote code that works for a Craig CLC512 t.v? if so please respond to this or if you know that there aren't any, please respond
:welcome to Satelliteguys richware1!
What Directv equipment are you using?
The only codes I could find are 10180 and 10161.
I have never heard of anyone finding a working code for this brand, I suggest doing a codesearch by volume, with tv on, volume up but muted:
1. tv
2. press and hold MUTE & SELECT for two blinks
3. enter 9 9 1, wait two blinks
4. enter 1
5. press and release VOL UP
6. point the remote at the tv and keep pressing and releasing the CH UP key, if and when the volume changes
7. press select to lock in code
Remember there are over 300 brands of tv, many having more than one code, give it time.
I figured you would be here sooner or later Edmund! From what I have read, no one has had any luck using the search method you posted, but it's worth a try for sure.
A learning remote may be the best solution. I assume that's what you are getting at Edmund.
Swap receiver locations
Media share on networked drive?
