Couldn't use my Birdog | SatelliteGuys.US
Alvn8r
81
Today I tried to use my Birdog to aim an Invacom SNH-031 LNBF but i couldnt pick anything up. my analog meter found all kinds of signals. Why can't the DOG find a bird?????
Should work fine, my positive ID satellite meter works with Ku, DBS and C-Band signals.
The Linear outputs of the QPH-031 are standard with the L.O. being 10750
(22Khz off)
If you have never used this meter for Ku signals you will find these signals are a lot harder to find than DBS satellites!
i switched lnbs with an old Direct lnb, found the 110, changed lnb, and it didn't read it. Bad LNB?????
110ºw is a circular polarized satellite, you would have to move the dish to another satellite (Linear) and change to a linear satellite on the Birdog.
What satellite are you aiming for?
Galaxy 10r but all i got was Dish Network 129, but that wouldnt show up on the DOG.
Ordered a Dish and LNB
New installation - no signal quality
