Coolsat Blind Scan Issue | Page 2 | SatelliteGuys.US
sidekick said:
Well, I certainly hope it works, as I would certainly hate to lose the imbedded sats that came with the receiver.
You won't lose the sats that came with the receiver-only ones you added. You will lose channels you scanned in. In other words when you reset it will look like it did out of the box.
Well, I deleted the AMC-9 TP that I added (Direcway at 12060) and the blind scan problem is gone. Any input as to why this might have happened would be enlightening.
You lucky dog! (pun intended) :)
I would not worry about it too much. A few of the FTA receivers seem to require a reset or a deleted TP now and then-they are not without bugs it seems. But it's really nothing to be concerned about and now you know how to fix the problem if it occurs again.
I would add that the Directway TPs seem to cause problems for some reason.
This is a common occurence when blind scanning. You will learn to spot it and handle accordingly. :)
roof mounting a 33" dish
11720 on G10r
