The pickets in the railing/gate whatever it is, and the vertical joints in the brickwork directly behind the dish in the photo. Suggests the camera was not 90 degrees straight up.pickets and mortar joints ?
Can you take a close up of the elevation setting? The dish mount looks parallel to the mast.
I'm also confused on the LNB skew. There are numbers on the holster, and numbers on the LNB itself. If it says I'm supposed to rotate the LNB to 21.6, is that using the numbers on the LNB?
That seems a bit off... Looking at the dishpointer website and dropping the location at various points in KS/MO, It looks like the skew should be somewhere from 1.4 degrees westward (KS/CO border) to 15.5 degrees westward (St Louis). Elevation looks to be between 40 and 46 degrees. SatelliteGuys has your location as Missouri/Kansas, so that's my best guess.
When aiming for 103W, set your receiver to 11940 V 20000 (RT/NHK mux). This TP, at least for me, is stronger than any of the NBC transponders, and most forgiving if the skew is a bit off.
Notice, you don't see a cow pasture in the photos.I'm in Ohio right now![]()
Both scales indicate elevation. There is no latitude scale on the dish. The "A" scale is used if the through bolt was installed using hole "A". The other side of the bracket is the "B" scale that is used if the through-bolt was installed using hole "B".
Thanks for the close-up photos. If the mast is plumb and the mount is assembled using hole "A", the pointer is approximately in the correct position for 37-39 degrees elevation.
So, I'm back home now, and I've set up my temporary rig on the pavement out front of my house. It's not completely level, as you can see in the photo, due to pavement being unlevel.
I've been trying to use Amiko's scanner to see if I can tune any satellites. I've tried 103 and 97, but can't seem to get even a blip. I'm perplexed, because I've aimed Dish Network dishes plenty of times, but I can't get anything on this.
Is there a way for the Amiko to scan for ANY frequency, even if it's not the correct satellite?
One other question: if I connect my Dish LNB to the Amiko and specify 61.5 or 72, will it find anything? I'm trying to troubleshoot and I'd love to be able to at least prove that I'm able to tune SOMETHING!
View attachment 131777 View attachment 131776 View attachment 131778
It was hard for me to, but I didn't give up. Make sure you have a clear view of the southern sky and don't trust those augmented reality apps.I'd recommend you watch K4EST's Amiko Mini HD RE setup videos. Check to see if your dish is not warped by laying it on a flat surface. If it's a geostationary satellite, you don't have to worry about a level pole. For elevation, I used my iPhone built in inclinometer by laying it horizontal yon the LNB arm.
Hope this helps
Oh trust me, I'm not going to give up!
I almost gave up, called an installer and when we quoted me his price $130 I went outside, and 3 hours later I got the signal.
The install menu for 97W KU in your photo shows "No TP". No satellite will be found unless an active transponder is entered for the receiver to lock onto. Don't understand why the satellite list has no preprogrammed transponders listed. Were the transponders erased?
If looking for 97w KU, set the LNBF skew to the proper rotation angle (see dishpointer.com) and enter an active transponder for 97w. I would suggest 12152 H 20000. Make sure the LNB Type is set to Standard LO 10750.
Limited time offer
