Combining Local TV Antenna with multiswitch | SatelliteGuys.US
matt74
11
Ontario
i have a zinwell 6 X 8 multi-switch that is connected to our direct tv i also have a local TV Antenna. Is there a way to connect them all together? I saw there is a Sat/Ant Diplexer will it work? if it does work how do i set it up?
that would depend on the type of dish you are using & the recvrs you have
the dish i am using is the 5 lnb one and the recvrs i am using is the standard direct tv recvr and an HD revcr with no PVR
Sports Pack Question
CSN Phils Games...Looks like...
