COBY LCD 29" remote 21.0 code | SatelliteGuys.US
upsss
529
68
AZ
Before I try to teach my 21.0 remote every key press for this new COBY 39" LCD TV, does anyone have a code that works beside turning on/off the TV? None of the codes in the remote manual worked at all.
Sorry, the title should be 39" not 29"
http://www.mydish.com/support/apps/remotecodes.aspx
[TABLE="class: basic"]
[TR]
[TH]#[/TH]
[TH]Code[/TH]
[TH]Success %[/TH]
[TH]Success Count[/TH]
[TH]Vote[/TH]
[/TR]
[TR]
[TD]1[/TD]
[TD]627[/TD]
[TD]77[/TD]
[TD]79[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]2[/TD]
[TD]607[/TD]
[TD]32[/TD]
[TD]9[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]3[/TD]
[TD]633[/TD]
[TD]24[/TD]
[TD]7[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]4[/TD]
[TD]625[/TD]
[TD]20[/TD]
[TD]2[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]5[/TD]
[TD]626[/TD]
[TD]13[/TD]
[TD]2[/TD]
[TD]
[/TD]
[/TR]
[/TABLE]
Some of the codes are better than just on/off but still some basic function don't work.
Thanks for the help but none of the codes really did do more than on/off and volume. I ended up teaching the remote all the important functions. This Learning mode is really great, never had a chance to use it before.
BTW, this COBY TV TFTV3925 is not bad from Fry's Electronics, 39" LCD for only $249.
I'm glad you like the TV. I myself would never recommend a Coby TV. Great price but noticeable difference in quality compared to other brands.
Yes, I know it is not a brand name, the picture is not bad and the price was right. It is only for the bedroom and so far I don't have any problems, also I have 30 days for a full refund.
Dish Distant Networks satellites
No MLB Strkezone Tonight??
