How many realignment calls are going to come in to dish because of the wobble & peaking dish to the best signal to get 129 now,when installers did some sacrificed 119&110 for better signal at 129?.![]()
If Ciel-2 goes past 129 W, it has to go all the way around the Earth at 2 degrees per day and take another shot at it.
Sorry, guess I should have put a smiley!!!!![]()
Go ahead, make fun of HD Roberts post but you'll see in a couple of days someone is gonna post that Ciel 2 past 129.We'll find out, sooooon!
And apparently no one read mine when I said this type of thing either![]()
Question so in less then 12 hours it will be at 129?
You're like a kid tracking santa claus![]()
LMAO!!! The best one yet!!If Ciel-2 goes past 129 W, it has to go all the way around the Earth at 2 degrees per day and take another shot at it.
Not possible. You will need a 3rd dish, or else a replacement dish that can "see" all 3 orbital locations.When the spot beam from 129 is active can they point it so it is picked up by the 110 dish or will I have to have a third dish at 129?
A Spotbeam from 129 that is picked up by 110?Okay, here is a dumb question:
In Hawaii we get signals on both 110 and 119 and also a spot beam from 110.
Dune
Digiblur and other uplink specialists:
Have you guys seen any signs that there may come some conus HD locals out of this?
Thanks.
Just the opposite.
They need to remove the CONUS HD locals from 129, because Ciel-2 has less CONUS transponders and lots and lots of spot beams.
If you don't live within a spotbeam from either Ciel-2 (129) or Rainbow-1 (61.5), you may be out of luck soon (in terms of HD Locals).
I think they're forgot to put the word "Turbo" - Dish using TC with 8PSK modualtion.A question for the transponder experts.
What is the technical difference between 8PSK rate 2/3 (used for Conus) and 8PSK Turbo Rate 2/3 (used for most of the spots-excluding southeast)?
Longitude 130.24
Two Line Element Set (TLE):
1 33453U 08063A 09026.64059299 .00000003 00000-0 00000+0 0 720
2 33453 000.0430 230.6702 0000442 265.8283 088.9544 01.00838821 493
Limited time offer
