Chaparral Corotor II+ C/Ku Feed | SatelliteGuys.US
wildboys
328
I have the Chaparral Corotor II+ C/Ku Feed shown in the photo in this link.
http://www.impaktproducts.com/product.php?productid=16178&cat=272&page=1
The piece shown to the right of the feedhorn.What is it for?Do i need to attach it to the feedhorn then attach my lnb to it or should i leave it off.My cband lnb will attach to the feedhorn with or without the piece.Should i leave this piece off the feedhorn or does it matter.
It's an elbo. I use it on one of my BUD's, I don't on the other. I can't visually see any difference, but reason would say, with it off there is less of an obstacle/interference. With it off, I can't get the weather cover on the dish, as it puts the lnb in the way. As far as performance, I don't think you would notice any difference. But, every little thing, as small as it may be, can add up.
Al
I leave mine off since I don't have a commercially fit cover anyway. Seems like anything added in thats not needed probably helps degrade signal and my kitty litter bucket cover still fits.
SD
Is it possible?
CoolSat Programming Help
