Channels mapping | Page 2 | SatelliteGuys.US
Channels mapping
ALL receivers have always shown them as a separate birds - what he WAS trying to say, is that some receivers show those 110 x-ponders as actual x-ponders 28-32, as opposed to the "moved" x-ponders of 8-12. ;) ;)
IMHO, I'm not entirely sure this is true - I do happen to have one of the first multisat IRD's (RCA480) & it's been awhile since I checked this. I'll hook it up & check it later & let everyone know.
My first generation to use 110 for HD RCA DCT-100 shows 110 as moved transponders to 119 - not separate.
My new H20 shows the 110W as a different satellite and has X's in the slot below the actual transponders.
Thus I am not sure how you can say ALL receivers have shown them as a separate bird - as I have already pointed out the RCA DCT-100 does not.
LyngSat.com ? ;)
Sorry, I am not a mathematician who has studied lyngsat enough to calculate that - and I am sure others on satellitguys.us are not either.
Your posts seem to make it appear D* can only get roughly 27Mbps out of a transponder. Clearly E* can get a lot more than that.
Thus my question.
You need just K-5 grade for that :D - to compare DTV SR & FEC with same Dish QPSK transponders using Lyngsat tables. Yes, practically you're right. Check also BFG's HD table here.
I stopped following the bandwidth crunch a long time ago, but I thought that DISH switched to 8PSK for its HDTV signals, which was supposed to get it 30% more data in the same bandwidth.
If someone has given you the formula, I am sure a third grader could do it.
However, if no one gives you the formula for adding fractions, one might be able to add 2+2 and still not be able to add fractions.
I recall Mike-DC05 (?) did post how to calculate bandwidth using SR, FEC, xPSK modulation. It was a couple years ago. Or more.
Yeah, DTV chaning the map pretty quickly. But most of core channels stay on same transponders. This new map pulled out some local channels with names, but many still keep generic. Will see if it could be solved.
I'm thinking if the numer of channel in range 9xx exist in EPG, then ppl from other regions could identify each one.
Code:
tpn1 - 12224:
 SID	VPID	APID	APID2	Name
 231,	90,	91,	0,	FOOD
 250,	110,	111,	0,	REAL
 263,	120,	121,	0,	LOGO
 269,	40,	41,	0,	HIST
 293,	60,	61,	0,	BABY
 302,	100,	101,	0,	NKTN
 309,	50,	51,	0,	GSN
 325,	10,	11,	0,	SPKE
 326,	80,	81,	0,	GAC
 327,	30,	31,	0,	CMT
 335,	130,	131,	0,	VH1
 378,	140,	141,	0,	NRB
 490,	990,	0,	0,	DTV
 596,	230,	231,	0,	TEN
 813,	0,	180,	0,	XM
 842,	0,	170,	0,	XM
 847,	0,	200,	0,	XM
 854,	0,	190,	0,	XM
[18 SIDs]
tpn2 - 12239:
 109,	0,	180,	0,	XM
 242,	50,	51,	52,	USA
 265,	60,	61,	0,	A&E
 278,	80,	81,	0,	DSC
 491,	990,	0,	0,	DTV
 593,	10,	11,	0,	PPV
 595,	230,	231,	0,	PBTV
 700,	120,	121,	0,	 NFL
 814,	0,	190,	0,	XM
 817,	0,	170,	0,	XM
 851,	0,	200,	0,	XM
 866,	0,	180,	0,	XM
 878,	30,	31,	0,	GMC
 996,	30,	31,	0,	GMC
[14 SIDs]
tpn3 - 12253:
 140,	120,	121,	122,	PPV
 145,	30,	31,	32,	PPV
 147,	10,	11,	12,	PPV
 149,	20,	21,	22,	PPV
 150,	140,	141,	142,	PPV
 151,	80,	81,	82,	PPV
 156,	50,	51,	52,	PPV
 158,	100,	101,	102,	PPV
 161,	60,	61,	62,	PPV
 163,	40,	41,	42,	PPV
 165,	90,	91,	92,	PPV
 170,	110,	111,	112,	PPV
 172,	130,	131,	132,	PPV
 722,	150,	151,	0,	NFL
 723,	160,	161,	0,	NFL
[15 SIDs]
tpn4 - 12268:
 921,	10,	11,	0,	LoCh
 922,	20,	21,	0,	LoCh
 923,	30,	31,	0,	LoCh
 924,	40,	41,	0,	LoCh
 925,	50,	51,	0,	LoCh
 926,	60,	61,	0,	LoCh
 927,	80,	81,	0,	LoCh
 928,	90,	91,	0,	LoCh
 929,	100,	101,	0,	LoCh
 930,	110,	111,	0,	LoCh
 931,	120,	121,	0,	LoCh
 932,	130,	131,	0,	LoCh
 933,	140,	141,	0,	LoCh
 934,	150,	151,	0,	LoCh
[14 SIDs]
tpn5 - 12282:
 144,	50,	51,	52,	PPV
 152,	90,	91,	92,	PPV
 155,	80,	81,	82,	PPV
 171,	40,	41,	42,	PPV
 174,	60,	61,	62,	PPV
 176,	30,	31,	32,	PPV
 177,	20,	21,	22,	PPV
 180,	10,	11,	12,	PPV
 724,	150,	151,	0,	NFL
 725,	160,	161,	0,	NFL
[10 SIDs]
tpn6 - 12297:
 108,	0,	180,	0,	XM
 122,	40,	41,	42,	PPV
 207,	10,	11,	0,	ESN
 208,	90,	91,	0,	ECL
 261,	20,	21,	0,	LRW
 276,	120,	121,	0,	NGC
 299,	80,	81,	0,	NIK1
 301,	50,	51,	0,	TVLD
 366,	30,	31,	0,	CRNT
 374,	130,	131,	132,	BYU
 550,	100,	101,	0,	IFC
 610,	110,	111,	0,	CSTV
 628,	60,	61,	0,	FSPI
 809,	0,	180,	0,	XM
 844,	0,	200,	0,	XM
 850,	0,	170,	0,	XM
 856,	0,	190,	0,	XM
 995,	130,	131,	132,	SC68
[18 SIDs]
tpn7 - 12311:
 142,	80,	81,	82,	PPV
 154,	90,	91,	92,	PPV
 179,	40,	41,	42,	PPV
 188,	60,	61,	62,	PPV
 189,	50,	51,	52,	PPV
 468,	10,	11,	0,	CBSW
 719,	20,	21,	0,	NFL
[7 SIDs]
tpn8 - 12326:
 102,	130,	131,	0,	NMX
 104,	130,	131,	0,	SMX
 105,	130,	131,	0,	SMXI
 111,	130,	131,	0,	KMX
 115,	130,	131,	0,	IAC
 204,	20,	21,	0,	HLN
 228,	50,	51,	0,	GEMS
 233,	80,	81,	0,	GEM
 255,	30,	31,	0,	i
 262,	40,	41,	0,	SOAP
 356,	10,	11,	0,	MNBC
 367,	100,	101,	0,	JTV
 399,	10,	11,	0,	DTV
 404,	60,	61,	62,	GALA
 480,	130,	131,	0,	ACT
 482,	130,	131,	0,	IAC
 597,	230,	231,	0,	JENA
 623,	120,	121,	122,	NESN
 624,	110,	111,	112,	FSNY
 654,	90,	91,	0,	FSBA
 720,	10,	11,	0,	NFL
 832,	0,	170,	0,	XM
 835,	0,	190,	0,	XM
 838,	0,	180,	0,	XM
 845,	0,	200,	0,	XM
[25 SIDs]
tpn9 - 12341:
 203,	130,	131,	0,	CRT
 232,	80,	81,	0,	FINE
 236,	120,	121,	0,	E!
 247,	10,	11,	12,	TBS
 252,	60,	61,	62,	LIFE
 273,	40,	41,	0,	BRVO
 296,	50,	51,	52,	TOON
 605,	100,	101,	0,	GOLF
 621,	20,	21,	0,	MSG
 622,	30,	31,	32,	YES
 630,	110,	111,	0,	FSS
 647,	90,	91,	0,	FSMW
 764,	20,	21,	0,	NHL
 818,	0,	190,	0,	XM
 830,	0,	170,	0,	XM
 861,	0,	180,	0,	XM
[16 SIDs]
tpn10 - 12355:
 130,	130,	131,	132,	PPV
 206,	100,	101,	0,	ESPN
 245,	90,	91,	92,	TNT
 360,	110,	111,	0,	FNC
 381,	10,	11,	12,	CBSW
 383,	20,	21,	22,	NBCW
 384,	50,	51,	52,	PBS
 387,	30,	31,	32,	ABCW
 389,	40,	41,	42,	FOXW
 625,	80,	81,	0,	SNY
 643,	60,	61,	0,	FSSW
 804,	0,	190,	0,	XM
 805,	0,	180,	0,	XM
 816,	0,	200,	0,	XM
 833,	0,	170,	0,	XM
 935,	120,	121,	0,	OR43
 938,	10,	11,	12,	LA2
 939,	20,	21,	22,	LA4
 941,	30,	31,	32,	LA7
 943,	40,	41,	42,	LA11
[20 SIDs]
tpn11 - 12370:
 107,	0,	190,	0,	XM
 251,	110,	111,	0,	OXGN
 253,	80,	81,	0,	LMN
 297,	10,	11,	12,	BOOM
 307,	90,	91,	0,	WGN
 350,	50,	51,	0,	CSP1
 402,	60,	61,	62,	UNIV
 504,	20,	21,	22,	HBOW
 606,	30,	31,	0,	OUT
 615,	120,	121,	0,	STS
 638,	100,	101,	0,	FSCN
 652,	130,	131,	0,	FSW
 653,	40,	41,	0,	FSPT
 803,	0,	200,	0,	XM
 821,	0,	170,	0,	XM
 822,	0,	180,	0,	XM
 824,	0,	190,	0,	XM
[17 SIDs]
tpn12 - 12381:
 900,	10,	11,	0,	LoCh
 901,	20,	21,	0,	LoCh
 902,	30,	31,	0,	LoCh
 903,	40,	41,	0,	LoCh
 904,	50,	51,	0,	LoCh
 905,	60,	61,	0,	LoCh
 906,	80,	81,	0,	LoCh
 907,	90,	91,	0,	LoCh
 908,	100,	101,	0,	LoCh
 909,	110,	111,	0,	LoCh
 910,	120,	121,	0,	LoCh
 911,	130,	131,	0,	LoCh
 912,	140,	141,	0,	LoCh
 913,	150,	151,	0,	LoCh
[14 SIDs]
tpn13 - 12399:
 160,	30,	31,	32,	PPV
 162,	20,	21,	22,	PPV
 167,	40,	41,	42,	PPV
 182,	50,	51,	52,	PPV
 185,	10,	11,	12,	PPV
 588,	230,	231,	232,	PPV
 726,	150,	151,	0,	NFL
 727,	160,	161,	0,	NFL
[8 SIDs]
tpn14 - 12414:
 224,	20,	21,	0,	TVGC
 240,	100,	101,	0,	HSN
 277,	60,	61,	0,	TRAV
 279,	90,	91,	0,	DHC
 291,	110,	111,	0,	DIS2
 312,	40,	41,	0,	HALL
 321,	130,	131,	0,	WHT
 330,	80,	81,	0,	BETJ
 331,	140,	141,	0,	MTV
 369,	120,	121,	0,	DSTR
 379,	10,	11,	0,	RFD
 422,	30,	31,	0,	EWTN
 594,	230,	231,	0,	CLPS
 802,	0,	170,	0,	XM
 825,	0,	200,	0,	XM
 836,	0,	180,	0,	XM
 839,	0,	190,	0,	XM
[17 SIDs]
tpn15 - 12428:
 103,	80,	81,	0,	DTV
 129,	60,	61,	62,	PPV
 227,	30,	31,	0,	INFO
 340,	40,	41,	0,	AVC
 362,	70,	71,	0,	TWC
 370,	10,	11,	0,	SNBC
 608,	20,	21,	0,	VS
 629,	50,	51,	0,	CSN
 642,	30,	31,	0,	FSWI
 701,	120,	121,	122,	GMX1
 702,	90,	91,	92,	GMX2
[11 SIDs]
tpn16 - 12443:
 106,	0,	200,	0,	XM
 229,	110,	111,	0,	HGTV
 241,	80,	81,	0,	TV1
 248,	100,	101,	0,	FX
 287,	130,	131,	0,	MILT
 329,	50,	51,	0,	BET
 341,	120,	121,	0,	ATM
 368,	40,	41,	0,	FIT
 376,	90,	91,	0,	NASA
 521,	60,	61,	62,	STZw
 609,	20,	21,	0,	ESPU
 620,	30,	31,	0,	FSNE
 632,	10,	11,	0,	SUN
 668,	120,	121,	0,	CSNC
 784,	120,	121,	0,	ESPN
 808,	0,	170,	0,	XM
 820,	0,	190,	0,	XM
 827,	0,	180,	0,	XM
 848,	0,	200,	0,	XM
[19 SIDs]
tpn17 - 12457:
 249,	90,	91,	0,	COM
 266,	10,	11,	0,	BIO
 280,	60,	61,	0,	TLC
 345,	30,	31,	0,	USN
 357,	20,	21,	0,	CNBW
 375,	100,	101,	0,	LINK
 377,	40,	41,	0,	TCT
 522,	120,	121,	122,	SEDG
 607,	80,	81,	0,	SPD
 613,	130,	131,	0,	FSC
 641,	110,	111,	0,	FSNO
 649,	50,	51,	0,	FSAZ
 801,	0,	170,	0,	XM
 812,	0,	190,	0,	XM
 834,	0,	200,	0,	XM
 853,	0,	180,	0,	XM
[16 SIDs]
tpn18 - 12472:
 961,	10,	11,	0,	LoCh
 962,	20,	21,	0,	LoCh
 963,	30,	31,	0,	LoCh
 964,	40,	41,	0,	LoCh
 966,	60,	61,	0,	LoCh
 967,	80,	81,	0,	LoCh
 968,	90,	91,	0,	LoCh
 969,	100,	101,	0,	LoCh
 970,	110,	111,	0,	LoCh
 971,	120,	121,	0,	LoCh
 972,	130,	131,	0,	LoCh
 973,	140,	141,	0,	LoCh
 974,	150,	151,	0,	LoCh
[13 SIDs]
tpn19 - 12486:
 212,	120,	121,	0,	NFL
 243,	20,	21,	0,	AS
 244,	60,	61,	0,	SCFI
 254,	110,	111,	0,	AMC
 284,	90,	91,	0,	SCI
 285,	100,	101,	0,	DTMS
 295,	30,	31,	0,	SPRT
 339,	80,	81,	0,	Fuse
 371,	50,	51,	0,	TCC
 372,	40,	41,	0,	TBN
 373,	130,	131,	0,	WORD
 612,	10,	11,	0,	FUEL
 826,	0,	190,	0,	XM
 862,	0,	200,	0,	XM
 864,	0,	170,	0,	XM
 865,	0,	180,	0,	XM
[16 SIDs]
tpn20 - 12501:
 884,	10,	11,	0,	LoCh
 885,	20,	21,	0,	LoCh
 886,	30,	31,	0,	LoCh
 887,	40,	41,	0,	LoCh
 888,	50,	51,	0,	LoCh
 889,	60,	61,	0,	LoCh
 890,	80,	81,	0,	LoCh
 891,	90,	91,	0,	LoCh
 892,	100,	101,	0,	LoCh
 893,	110,	111,	0,	LoCh
 894,	120,	121,	0,	LoCh
 895,	130,	131,	0,	LoCh
 896,	140,	141,	0,	LoCh
 897,	150,	151,	0,	LoCh
[14 SIDs]
tpn21 - 12516:
 131,	20,	21,	22,	PPV
 132,	40,	41,	42,	PPV
 138,	50,	51,	52,	PPV
 214,	90,	91,	0,	DTV
 218,	990,	0,	0,	DTV
 239,	110,	111,	0,	CSHP
 256,	120,	121,	122,	TCM
 365,	80,	81,	0,	GTV
 526,	30,	31,	32,	ENCR
 533,	60,	61,	0,	EWAM
 599,	230,	231,	0,	HUST
 637,	100,	101,	0,	FSOH
 828,	0,	170,	0,	XM
 831,	0,	190,	0,	XM
 840,	0,	180,	0,	XM
 846,	0,	200,	0,	XM
 977,	10,	11,	0,	BA54
[17 SIDs]
tpn22 - 12530:
 133,	50,	51,	52,	PPV
 260,	120,	121,	0,	WE
 294,	60,	61,	0,	KIDS
 300,	80,	81,	82,	NIK2
 537,	30,	31,	32,	SHO
 547,	110,	111,	0,	FLIX
 592,	230,	231,	232,	PPV
 601,	20,	21,	22,	NBA
 634,	130,	131,	132,	FSFL
 636,	100,	101,	0,	FSD
 645,	40,	41,	0,	FSRM
 659,	90,	91,	0,	RSNa
 751,	100,	101,	0,	NBA1
 819,	0,	200,	0,	XM
 829,	0,	190,	0,	XM
 837,	0,	170,	0,	XM
 859,	0,	180,	0,	XM
[17 SIDs]
tpn23 - 12545:
 101,	110,	111,	0,	FREE
 201,	50,	51,	0,	DTV
 209,	10,	11,	0,	ESN2
 220,	100,	101,	0,	DTV
 225,	80,	81,	0,	REEL
 282,	140,	141,	0,	APL
 334,	110,	111,	0,	FREE
 355,	60,	61,	0,	CNBC
 498,	100,	101,	0,	DTV
 520,	30,	31,	32,	STRZ
 523,	20,	21,	0,	SBLK
 529,	40,	41,	0,	EWST
 580,	110,	111,	112,	FREE
 600,	100,	101,	0,	DTV
 640,	130,	131,	0,	CSNC
 644,	120,	121,	0,	ALT
 795,	100,	101,	0,	DTV
 800,	110,	111,	0,	FREE
 852,	0,	170,	0,	XM
 855,	0,	180,	0,	XM
 858,	0,	190,	0,	XM
 860,	0,	200,	0,	XM
[22 SIDs]
tpn24 - 12559:
 135,	130,	131,	132,	PPV
 292,	60,	61,	62,	TDIS
 626,	90,	91,	0,	MASN
 705,	10,	11,	0,	NFL
 706,	20,	21,	0,	NFL
 710,	40,	41,	0,	NFL
 713,	30,	31,	0,	NFL
 714,	100,	101,	0,	NFL
 716,	120,	121,	0,	NFL
 717,	80,	81,	0,	NFL
 823,	0,	190,	0,	XM
 843,	0,	170,	0,	XM
 863,	0,	200,	0,	XM
 867,	0,	180,	0,	XM
[14 SIDs]
tpn25 - 12574:
 119,	30,	31,	0,	PPV
 333,	90,	91,	0,	MTV2
 351,	80,	81,	0,	CSP2
 398,	120,	121,	0,	DTV
 703,	130,	131,	0,	RZC
 704,	30,	31,	0,	NFL
 707,	10,	11,	0,	NFL
 708,	20,	21,	0,	NFL
 709,	60,	61,	0,	NFL
 711,	50,	51,	0,	NFL
 712,	120,	121,	0,	NFL
 715,	40,	41,	0,	NFL
 753,	10,	11,	0,	NBA3
 841,	0,	180,	0,	XM
 868,	0,	170,	0,	XM
[15 SIDs]
tpn26 - 12588:
 979,	10,	11,	0,	LoCh
 980,	20,	21,	0,	LoCh
 981,	30,	31,	0,	LoCh
 982,	40,	41,	0,	LoCh
 983,	50,	51,	0,	LoCh
 984,	60,	61,	0,	LoCh
 985,	80,	81,	0,	LoCh
 986,	90,	91,	0,	LoCh
 987,	100,	101,	0,	LoCh
 988,	110,	111,	0,	LoCh
 989,	120,	121,	0,	LoCh
 990,	130,	131,	0,	LoCh
 991,	140,	141,	0,	LoCh
 992,	150,	151,	0,	LoCh
[14 SIDs]
tpn27 - 12603:
 202,	90,	91,	0,	CNN
 286,	100,	101,	0,	HOM
 290,	80,	81,	0,	DIS1
 298,	10,	11,	0,	NOG
 337,	50,	51,	0,	VH1C
 354,	120,	121,	0,	G4
 501,	20,	21,	22,	HBO
 528,	60,	61,	0,	ELOV
 532,	110,	111,	0,	EACT
 538,	30,	31,	32,	SHO2
 539,	40,	41,	42,	SHO3
 544,	130,	131,	0,	TMC
 810,	0,	190,	0,	XM
 811,	0,	200,	0,	XM
 870,	0,	170,	0,	XM
 872,	0,	180,	0,	XM
[16 SIDs]
tpn28 - 12618:
 944,	10,	11,	0,	LoCh
 945,	20,	21,	0,	LoCh
 946,	30,	31,	0,	LoCh
 947,	40,	41,	0,	LoCh
 948,	50,	51,	0,	LoCh
 949,	60,	61,	0,	LoCh
 950,	80,	81,	0,	LoCh
 951,	90,	91,	0,	LoCh
 952,	100,	101,	0,	LoCh
 953,	110,	111,	0,	LoCh
 954,	120,	121,	0,	LoCh
 955,	130,	131,	0,	LoCh
 956,	140,	141,	0,	LoCh
 957,	150,	151,	0,	LoCh
[14 SIDs]
tpn29 - 12632:
 467,	10,	11,	0,	CBSE
 469,	20,	21,	0,	NBCE
[2 SIDs]
tpn30 - 12647:
 100,	120,	121,	0,	DTV
 116,	130,	131,	0,	DTV
 125,	80,	81,	82,	PPV
 200,	120,	121,	0,	DTV
 234,	140,	141,	0,	DTV
 258,	40,	41,	0,	FMC
 308,	60,	61,	0,	SLTH
 500,	120,	121,	0,	DTV
 502,	90,	91,	92,	HBO2
 505,	20,	21,	22,	HB2W
 507,	10,	11,	12,	HBOF
 508,	50,	51,	52,	HBFW
 512,	30,	31,	32,	MAX
 545,	110,	111,	0,	TMCw
 549,	100,	101,	0,	SUND
 879,	0,	190,	0,	XM
[16 SIDs]
tpn31 - 12661:
 123,	130,	131,	132,	PPV
 311,	80,	81,	0,	FAM
 380,	10,	11,	12,	CBSE
 382,	20,	21,	22,	NBCE
 386,	30,	31,	32,	ABCE
 388,	40,	41,	42,	FOX
 527,	100,	101,	102,	ENCw
 542,	90,	91,	92,	EXTR
 579,	130,	131,	132,	PPV
 598,	230,	231,	0,	XCSS
 604,	130,	131,	132,	PPV
 631,	110,	111,	0,	SS
 651,	50,	51,	0,	FSNW
 656,	60,	61,	0,	CSNW
 880,	10,	11,	12,	NY2
 881,	20,	21,	22,	NY4
 882,	40,	41,	42,	NY5
 883,	30,	31,	32,	NY7
[18 SIDs]
tpn32 - 12676:
 119,	250,	251,	0,	PPV
 230,	60,	61,	0,	DIY
 264,	50,	51,	0,	BBCA
 271,	80,	81,	0,	HInt
 317,	110,	111,	0,	QVC
 353,	20,	21,	0,	BTV
 426,	120,	121,	122,	GOL
 503,	10,	11,	12,	HBOS
 513,	30,	31,	32,	MMAX
 514,	40,	41,	42,	MaxW
 530,	90,	91,	0,	EMYS
 531,	140,	141,	0,	EDRA
 540,	130,	131,	132,	SHOw
 602,	100,	101,	0,	TVG
 614,	120,	121,	122,	GOL
 765,	250,	251,	0,	NHL
 806,	0,	180,	0,	XM
 857,	0,	170,	0,	XM
[18 SIDs]
Sunday, December 3, 2006 at 23:24.29 GMT
I see many differences beetween the data and DBSForum table; perhaps those data taken from opposite coast and by different equipment in different time.
DirecTV is running around 30mbps per transponder just like E* on their QPSK transponders. This is from the muxes I've looked at on 101, 110, and 119.
And yes, E* gets about 40mbps on their 8PSK transponders.
And last one for 119W.
Code:
tpn27 - 12603:
 425, 10, 11, 12, FSE
 616, 10, 11, 0, FSE
 412, 20, 21, 0, MEXI
 405, 30, 31, 0, TELE
 406, 40, 41, 0, TELW
 418, 50, 51, 0, MEX
 410, 60, 61, 0, MUN2
 455, 80, 81, 0, CTV9
 450, 90, 91, 92, JADE
 428, 100, 101, 0, POR3
 427, 110, 111, 0, TYC
 424, 120, 121, 0, NDTV
 875, 0, 170, 0, XM
 876, 0, 180, 0, XM
 871, 0, 190, 0, XM
 874, 0, 200, 0, XM
 492, 990, 0, 0, DTV
[17 SIDs]
tpn28 - 12618:
 100, 10, 11, 0, DTV
 466, 10, 11, 0, HDN
 476, 20, 21, 0, ES2H
 563, 0, 170, 0, XM
 564, 0, 180, 0, XM
 493, 990, 0, 0, DTV
[6 SIDs]
Thursday, November 23, 2006 at 19:35.13 GMT
Notice that, in this channel map, DirecTV's 119 satellite, odd transponder test channel's (492) source is transponder 27 and its evens (493) test source is transponder 28. I had thought that all five of DirecTV's odd numbered transponders in this slot were going to be operated as spot beams, which would have made it an inappropriate transponder for a universal test channel, but upon inspection of the entire transponder 27 channel program list, it looks like it is now carrying all national,and therefore CONUS, programming.
Does anyone know if transponder 27 had previously been operated as a spot beam? In DirecTV's 101 slot, they have 38 transponders of uplink capacity that are downlinked 44 times at a total of six different spotbeam transponder frequencies. In the 119 slot, they have 11 transponders but can uplink to them from three different sites, meaning they can uplink 33 transponders, so if seven are now CONUS down, then the remaining 26 are being spread an unknown number of times among four spot transponder frequency beams. I guess the ratios are similar, but we don't have as much information regarding the 119 spot beams as we so the 101 spot beams because the DBS hobbyist/enthusiasts who had collaborated to figure out just what DirecTV was doing with its 101 spot beams were not sufficiently motivated to do the same thing when 119 went into operation.
The test transponders for Sat 101 test channels 490 and 491 are transponders 1 and 2, respectively. The test source for Sat C test channel 494 is actual transponder 30, which, due to non-standard intermediate frequency shifting, is "seen" as transponder 10 on many test regimens.
tivo
Help with DVR Remote
