No power? cool...never saw one like that before?I received my hdmi bi-directional 1 in 2 out or 2 in 1 out with no power supply needed, passes 4k to tv #1 and hd to tv#2
Amazon product ASIN B01FJOPJ34
No problem with splitters here. Netflix/VOD/etc all work fine.I believe , as I have heard complaints from customers, and seen negatives , that HDMI splitters will negate the effect of certain Hopper 3 features .
I would use the RF modulator for a mirrored TV as I always do, not the best "oh my god HD" picture but it's mirrored , easy to do.
If I am the only one experiencing problems with HDMI splitters in my area, then let me know. Netflix issues, and VOD problems with the HD splitter .
RF modulators are cheap use composite// RCA and a Coax cable to TV 2 .
Which Arc are you on and what kind of splitter are you using? Just curious so I can relay this to Dish and my FSM.No problem with splitters here. Netflix/VOD/etc all work fine.
H3 has just been Eastern. HWS was previously Western before switching to Eastern. A couple of different brands. I think the H3 is probably a Sewell 2 port. None of the two ports were over $25.00 the four port I have on a Joey2 was also inexpensive, probably not more than $50.Which Arc are you on and what kind of splitter are you using? Just curious so I can relay this to Dish and my FSM.
Thank ya
I have a Red, White and Yellow RCA composite cable between the two rooms and DO have a component input on the 2nd TV in the kitchen.
not if you want 4kNo problem with splitters here. Netflix/VOD/etc all work fine.
Limited time offer
