can not pair my logitech revue with my vip722 dvr | SatelliteGuys.US
caboclipper
59
hello everybody
can not get my logitech revue paired with my vip722 dvr
i do all the installation steps, then when my dvr gives me a code on the screen I enter that code into the configuration screen on the left, however every code I enter says tha the pairing failed.
I have done it 1,000 times, same result.
Any ideas ?
#1 Do you have the internet hooked up to the google box?
IF not do so and make sure it shows it's connected.
#2 Do you have the 722 hooked into the google box via hdmi?
IF not hook it up via hdmi so it can control it.
IF all else fails you can unplug the google box and reboot it. IF that doesn't work try settting up the dish receiver as a 722k and see if that works.
thank you MikeD-CO5
Yes I have the internet hooked up to my google box via wifi
Yes I have my 722 hooked into the google box via hdmi
I will try what you say, will reboot, let you know the outcome
DISH HD for life?
An open letter to the DIRT team at Satelliteguys
