Can Dish and Cable Co-exist on Coax? | Page 2 | SatelliteGuys.US
I could be wrong, but I don't believe that method will work if Hoppers/Joeys are involved. Which Dish receivers are you using that setup with successfully?
If I remember I had successfully used this with the Dish Hopper and cable internet. It worked very well.. As for Joey. there was a separate run from the dish Joey using an alternate switch.
Diplexers will work however the issue is that neither Dish or the cable company allows them to be used in this manner.
The cable guy comes out he is going to blame the problem on the diplexer and disconnect your satellite tv and use the line for cable.
The dish guy comes out, will disconnect the cable and use the line for Dish.
Typically neither technician will just run a separate wire, and will disconnect the other service and tell you to call them to install their service correctly.
So best to use separate wiring.
Reactions: ZandarKoad
Returning to Dish after 5 years of streaming and cable
