Can a satworks 3618 control a Bud polarity | SatelliteGuys.US
tontine
9
My Satworks 3168 has connections on the back that look like the BUD polarity connections. Are these functional? Can I use them to change polarity on my BUD? How would I control them with the satworks programing?Thanks for any help, Mike
If it has connections on the back for a polarotor then it should work. I havent had my 3618 in a couple years but in the menu setup it should say "skew"
I had a 3618 slaved to my 922. It had a skew adjustment somewhere in the menu, but I never had to use it since the 922 takes care of that. I now have a 3688, it has the same hook ups in the back as the 3618 and the opiton of turning the skew on or off in the antenna configuration. As a shot in the dark, I would say yes it will operate the polarities on a BUD.
Please help Invacom quad LNB = Channel loss
G10 RTN low signal tonite
