C-Band Receiver and FTA | SatelliteGuys.US
jself1982
1,272
South Carolina
Can you connect an FTA dish to a C-Band receiver and get KU thru the C-Band receiver? I know the motor wouldn't work but would you get signals thru the C-Band receiver??? Just curious.
Most Analog C-Band receivers do both C and Ku band!
All DVB receivers do both C and Ku band!
You require the correct LNBF for each band!
sure you can (with a twist)
most C/KU analog boxes can not change polarity of a LNBF (the LNB's most of us use). So they are defaulted to H polarity if hooked up directly. IN those cases, you need to slave it from your digital box.
If you use an old LNB with the 3 wires for polarity (older C Band dishes use these), then you could :)
FortecStar 90cm dish help?
Spotted my first FTA'r - finally!
