C-Band FAQ's idea thread | Page 2 | SatelliteGuys.US
A 4dtv faq from Usenet!
dfergie said:
Since there is not a thread on this and there seems to be renewed interest in BUD's... lets all put our ideas in this thread, from which a proper FAQ's Thread can be made and maintained.
I view usenet and found the following on the newsgroup for 4DTV...some decent info here....
4DTV FAQ
Table of Contents
1. General
1.1 What is 4DTV?
1.2 What receivers can be considered to be 4DTV receivers?
1.3 What digital receivers are not 4DTV receivers?
2. Digicipher II
2.1. What is Digicipher II?
2.2. What is the difference between DVB and DCII?
3. Frequently asked questions.
3.1 What can I do if the IPG is not downloading?
3.2 What can be done about the weak HBO/Max digital channels?
3.3 How can I set the remote to control the volume on the receiver?
3.4 Which VideoCipher modules are compatible with 4DTV?
3.5 How should I prepare for a Master Reset?
3.6 How do I interpret the meaning of the Diagnostic Screens?
3.7 What are the real names of the satellites in the 4DTV chart?
3.8 What are the differences between a DSR 920 and a DSR 922?
3.9 What are the differences between a DSR 920 and a DSR 921?
4.0 Autoresponders
1. General
1.1 What is 4DTV?
4DTV is a consumer level satellite receiver designed to receive a digital
transmission format which was created and developed by General Instruments.
4DTV has been manufactured under different company names, such as Next
Level, G.I, and Motorola. G.I is currently owned by Motorola. Next Level
was only a subdivision of G.I and this name is no longer in use.
All 4DTV receivers are currently manufactured by the General Instruments
division of Motorola. Current 4DTV models are:
DSR 920 (US IRD)
DSR 921 (Canadian IRD)
DSR 922 (Newer model US IRD)
DSR 905 (DCII digital sidecar)
Other StarChoice Canadian Receivers possibly may be considered to be 4DTV.
Only General Instrument consumer level receivers are called 4DTV receivers.
G.I. also produces commercial and educational receivers that are able to
process Digicipher II signals, but they are not called 4DTV. This is only
due to the nomenclature used by G.I.
DSS and DBS small dish receivers definitely are not 4DTV receivers. Dish
Network, DirecTV and Bell ExpressVue receivers for example do not process
Digicipher II signals and there for are not 4DTV or Digicipher II.
MPEG 1.5 and MPEG DVB receivers are not 4DTV or Digicipher II.
Although 4DTV receivers have a renewable security slot, this slot currently
serves no purpose. Any receiver that uses a CAM, H-Card or Hu-Card is not a
4DTV receiver.
2. Digicipher II
Digicipher II is Motorola's (G.I's) MPEG-2 based distribution system.
It's used by about many of "cable" channels in North America to distribute
their video to cable headends, DCII is also used by Canada's StarChoice
direct-to-home service.
Where DVB and DCII are really different is in how the channel definitions
get into the receiver. DCII was designed before the DVB standard was
ratified and General Instrument (now a part of Motorola) designed their
own scheme without any interfacing to the work being done by the DVB team.
For detailed information on Digicipher II and MPEG DVB see:
http://www.coolstf.com/mpeg/index.html#dcii
http://my4dtv.tripod.com/ipgfix1.htm
These channels can be very difficult or impossible to receive. In many
areas of the country it appears that a 10' dish is needed. If you have
a dish smaller than 10' it needs to be peaked to the arc and properly
tuned. There is a chance that you will not be able to receive these
channels no matter what is done.
For info on peaking the dish see:
http://www.geo-orbit.org/sizepgs/tuningp2.html
For this information and other help with the remote see:
http://prestocomm.netfirms.com/remotehelp.html
VCII (or VideoCipher II) was the original VideoCipher technology, which was
compromised very early on. Many people modified the VCII module in order to
watch subscription programming without paying for it. This technology was no
longer manufactured after 1989, and was completely replaced by the VCII+
technology in 1993. VCII modules were black. VCII modules are not compatible
with 4DTV IRD's.
The following modules are compatible with 4DTV, but there have been a few
people reporting they have had difficulty getting the VCII+ module to work
with a 4DTV. The VCII+ module should be compatible, but no absolute promises
can be made.
VCII+ (or VideoCipher II Plus) was a more secure technology mainly because
GI integrated a bunch of separate chips into a single secure chip. The VCII+
boards also supported more scrambled channels than the VCII (256 tier bits
instead of only 56). VCII+ modules were originally the lighter color blue,
and then changed to pink to denote that they were covered by the Consumer
Security Protection Plan (CSPP), which guaranteed a free upgrade to VCRS
if the VCII+ security was compromised within the first three years of
ownership. These began shipping in 1990 and stopped shipping in 1992.
VCRS (or VideoCipher Renewable Security) was an enhancement to the basic
VCII+ technology, but added the security card (known as TVPassCard), which
is the replaceable security. The VCRS is shipped without a TVPassCard, but
is designed to accept a card if the base module becomes compromised. In that
event, all base modules without a card would no longer be able to decrypt
the signals. VCRS boards are navy blue or purple to denote that they can be
exported out of the US. The purple modules were known as VCRSi, but were
functionally the same. All VCRS boards were covered by the three year CSPP.
They began shipping in 1992, and stopped being manufactured in 1998.
http://my4dtv.tripod.com/mr.htm
http://home.austin.rr.com/drlev/Diagscrn/diagscrn.htm
http://www.4dtvforum.com/sat_chart.shtml
http://members.rogers.com/4dtv/
http://members.rogers.com/4dtv/922/index.html
The DSR 920 is a US IRD and can only be authorized for US programming
providers. The DSR 921 is a StarChoice Canadian IRD and can only be
authorized by StarChoice. The hardware and firmware in these 2 models
are identical.
4.0 Discussion Forum Info
Below is a list of links the archived messages at
http://www.satforums.com . This list also can be
found at http://www.macross.com/~drlev .
Installation Information and Discussions
http://www.macross.com/~drlev/InfoInstDisc.html
Common Questions, Tips and Information
http://www.macross.com/~drlev/CommonTipsPart1.html
http://www.macross.com/~drlev/CommonTipsPart2.html
Reception Problems, Discussions and Information
http://www.macross.com/~drlev/RecProbDiscInf.html
STARCHOICE 921 IRDs
http://www.macross.com/~drlev/SC921.html
DSR 905 Info.
http://www.macross.com/~drlev/905Info.html
This came from a newsgroup on the 4DTV usenet
dfergie said:
If you will put the link to the FAQ's I will add that stuff when I get up this evening...
No link in the normal sense of the term..
It was on the 4DTV newsgroup on USENET...you need a newservice and news reader like free agent to subscriibe (free stuff)
I do not know where it originated!
Jeff
Another great source of 4DTV info
For this one you need a newsfeed (USENET)...most providers have an address like news.***.***.com etc. You could use outlook express but can also get a free Newsreader( free Agent) at www.forteinc.com
download all groups (over 80,000 on almost any subject) and search for 4dtv...not much right now but it goes in spurts!! Most providers do not have room for any binary groups but, usually carry the text ones.
Jeff
Perfect...I guess I did not look hard enough, being a newsgroup junkie!!!
BTW: there is lots more if you search for Satellite on the groups...a good reason to get the reader and newsfeed....WWW, is only part of the Internet!!!!
regards
jeff
This very nice and helpful/thanks guys
Hello I am jackpeas in Chicago,ILL.You guys are the best/you are not thinking of self.Its the new guy who is lost and confuse and dont know where to start.You got video,pictures,and guys who care.Thanks
Hi Jackpeas
I guess just look at it this way...I think we were all lost when we started! Necessity is the ......and so it goes!
have fun!
Jeff
Would you add this. It comes up way too often.
Unless you are in Brasil or a neighboring country, you will not be able to receive any of the BrasilSats.
anyone here from the east texas area?
Will a 100 K Nise floor LNB work with digital receivers?
