BSC621 KU band problems solved | Page 2 | SatelliteGuys.US
I think the 4 footer would be good at either 99 or 121. Conical scaler ring helps but most of these two sats will be good for the perm channels.
I'd save your 6 footer for some harder to lock sats.
BTW....do you have any success on the 6 foot on 89W or 87W feeds in the past? What about 103W (ION)?
89 I can get Pentagon & Nebraska PBS
87 I can lock almost everything real strong
This TV & TVU are at 75 quality
ZNS TV at 65
Radio Mux at 45
Unemployment/@Sports 45
These are on the Pansat where 30 is threshold on a 3/4 FEC. ThisTV is at 5/6 FEC so it needs at least 45 to be stable
103 is tough. Can get ION really good but the rest is tough to get
121 I can lock everything you posted but AmericaOne at 80+ quality. TVW/Sportsman at 90+
Looks like mine is ok.. I think.
Here is a pic of my BSC621-2 with S#.
Does this look correct?
Care to post pics looking down the throat of your fixed BSC621?
I checked mine against the "Fix It" PDF and it says I'm fine. :up
Signal Q says otherwise. Performs about as well as my 75e :mad:
I had it once but after a limb the size of my shin fell on my BUD, I haven't got the Ku side working well yet. :o
Where is this "Fix It" pdf?:confused:
Edit: Never mind. I found it here.
Anyone Had Their Extigy Die?
Major Pixelation-across many sats
