Bsc621 C/ku Lnbf | SatelliteGuys.US
Bsc621 C/ku Lnbf
lumpkin666
941
USA
Hey guys, so I'm about ready to start using a BUD to get some DVB C and KU band stuff, and I'm wondering of this LNBF combo can be used by somehow bypassing the internal DISEQC. Since I have other dishes that I want to feed through a single line, I wanted to use a DISEQC switch and combine two other KU-Band feeds with the C-Band and KU-Band feeds from this dish. Is this possible using this LNBF combination?
you want to bypass the internal Diseqc switch and use an external one ?? yes this will work . the BSC621 you don't have to use the internal switch you would just have to run coax to both c & ku connections.
Actuator wiring question
master reset on DSR-922
