no problemo my rant is over now back on trackNeutron said:Enough! If you have a problem with someone please take it to PM.
Uh yaaaaaa ... I just read that ... range of ports. THANKS! Guess it helps to have more than one socket for any service. 4444 is the UDP port that Mr Cohen specifies to have open.cdru said:There is likely your problem. It's actually a range of ports starting at 6881 going to 6999. BT uses TCP, so checking UPD isn't necessary. And I'm not sure what the 4444 port is for. Ever heard of it and never have opened it when I've used BT. Open up that range and your speeds will likely increase. Also remember that your download speeds are somewhat poportional to your upload speeds. You will only start to download at a trickle until you have enough to start sharing, then as others start downloading from you, your rates will increase (up to what can be supplied to you). But if only one person is seeding then you can only get as fast as they can send it to you.
Perhaps it is time to start the SatelliteGuys.US UFC?!?! Any thoughts Scott?Neutron said:Enough! If you have a problem with someone please take it to PM.
LER said:note that downloading copyrighted materials is against site policy as well as law.
You are very close to getting this thread killed.
LER
puck71 said:As that article mentioned, the MPAA has been focusing on BitTorrent sites for the past year or so. Many major sites have been shut down in that time, leading to a huge fragmentation of the "market" (for lack of a better word). It definitely isn't a safe or anonymous way to break the law, but in general they only go after the sites themselves, not the users. This article may be the first indication that they're changing that approach.
Charter didn't do it, the MPAA or RIAA got your IP and sent it to Charter, and they shut down or suspended your account. They do that on occasion, but by "go after" I really only meant legal action, not warnings.Madtown HD Junkie said:As i said above....they caught my IP downloading from a bittorrent site. last time I have tried that.
Limited time offer
