for magnets, check out burglar alarm supplies. They have packages of 1/4 inch round by 1 inch bare magnets. If you can't find a supply house, check out an installer - not sales - but the tech.
How about Lexan/Lucite/some other thermoplastic or acrylic for the disc? If you had a piece it could be cut to size with a hole saw. Can you cure your locking collar with a little touch of a lathe, dremel or grinder? I'm really enjoying following this effort, very cool.
:up
We talked about using some plexi-glass or plastic of some kind. The problem with plastic is that if it isn't cut, just right, or drilled just right, it cracks/shatters and you get to start over. If you go with the more forgiving plastic, it might not be rigid enough with the heat in the Summer. The only reason I was trying the mini-cd, is because it was already cut to size with correct size hole in the middle.
As far as truing up the existing locking collars, I don't have a lathe or a grinder. The best I have is a Dremel with a grinding wheel, but just don't have the precision measuring tools to make sure it is square. I will take these with me, and if I can't find what I am looking for will take these by a machine shop and have them squared up.
I was thinking of putting your little disc with hot-melt glue into the toaster oven for an hour of light baking.
But, then I remembered that those magnets may lose some of their suck at about 80º Centigrade.
So, double check my facts, and see what that is in ºF, and proceed accordingly.
I was thinking if the aluminum plate was nice 'n hot when you shot it with hot glue and pressed the magnet in place, that would work.
But regardless, it looks like you're well on the way to success.
I asked my Radio Shack manager about end-actuated reed switches.
He said they used to carry 'em.
We haven't checked the catalog yet, but if they're $2..$5, that might still be attractive.
That contact glue you started out with, is looking better every day.Wikipedia said:Glue guns come in a low-temperature and a high-temperature (hot-melt) version.
Low-temperature glue guns heat up to about 250º F (120º C), and are well suited when high temperatures are undesirable, for lace, cloth, children's crafts, etc.
High-temperature guns heat up to around 380º f (195º c) and produce a stronger bond.
Limited time offer
