BEV 6100 digital output cable Help!! | SatelliteGuys.US
buckspaul
Hi, I have a BEV 6100. I am having a hell of a time finding the correct digital (fiber optic) cable as the 6100 has a male output. does anyone know what the correct cable is for this receiver. thanks
I have two Bev 6100s and both are standard TOSLink (fibre/optical) cables. Any standard Optical digital cable will work.
Weird. Are you the first owner? If you are it may be a QC problem from the mfr. If it's second hand maybe it's a broken end from the previous toslink cable?
btw, would you be in Ohio?
My best guess is, it looks like the dust cover (door) is broken and that is what is preventing you from connecting the cable. If you can "remove" the cover your cable should work.
2 receivers on *c
Bell ExpressVu Lets Viewers 'Discover' HD Programming
