Best dual lnb for T-5? | SatelliteGuys.US
jjmaster
23
What is the best standard dual LNB to pull in T-5?
I was looking at the review for the Extreme II with 10750 LO, however it seems to be a single LNB. Do they make a dual version to run two receivers?
Any recommendations for dual LNB's?
If you want just KU, the Sadoun LNB is pretty good. I use one with no issues
If you want both KU & DBS, get the Invacom Quad (2 KU outputs, 2 DBS outputs)
Thanks! Looked at the Sadoun KUL2. I think this is what I am looking for.
Out of curiousity, did you ever do a comparison with the Extreme II? I saw your comparison was to the regular Extreme.
Driectv Oval for FTA signal possible?
Possible Price drops in FTA receivers??
