Yes i'm connected to the Eagle Aspen. Do you think I should purchase a different one? Is that why I'm only getting about 24% quality nomatter how I position the dish? What else could be the cause? I hear FSSN is a strong signal so I'll wait until Friday when it goes live to see how the quality looks.
Another note, when you blind scan for channels, make sure you check each channel that is found. You may be looking for FSSN but it may have scanned in under a different, generic name (like Service 'N' or TV 'X' TP 11.825 V).
My brother is going to emailo me some information on FSSN-UND channel, should come in a few minutes.
Radar
I was able to find the Sat at 91W and have about 24% quality. Moving the dish very slightly any direction only reduces to the quality. I'm hoping to try for the game on Friday and see what happens.
its up 15 minutes before game time and logs as UND-FSSN (which is better than the old generic "TV1" it use to log as)![]()
I'm wondering if the OP is truly on G17 and not AMC4....here me out
The original TP on G17 that had the color bars and a few scrambled channels was at 12060 V 26700 but changed recently. I posted the new info above
There is also a TP on AMC4 called the "HotelVision" mux that has scrambled channels at 12060 H 26700
Unless the OP changed the transponder on G17 to what I posted above it is VERY possible he is getting AMC4....the low signal quality gave me some hints especially if he moved the dish any direction he loses signal. The mux on G17 is much stronger than 24 max
just using my thinking voice here....
Thank god!! Any idea why my quality is still so low?
Limited time offer
