AZBOX HD ELITE or PREMIUM | Page 3 | SatelliteGuys.US
I see no one of the receivers had a disk.
Is that IDE [ATA] connector with sort of terminator connected ? Anyone did try to connect a PATA disk to that ?
You can put to partitions on an ide drive.One for the linux OS and the other partition for recording.I did this and it worked fine.
Nice. Thanks for the info.
Anyone else with the AZbox used IDE disks ? Post please your experience.
Maybe this will help?
Just confirming that the ATSC is not included...
Dear me,
1) ATSC tuner is a add-on you can Plug ATSC tuner on receiver like second
tuner.
2) DVB-S/S2 is the tuner that comes by default, others tuner should be
bought separately.
Best regards,
Hugo Condessa
OpenSAT, Lda. – C.E.O.
T: +351.251.656.134
F: +351.251.652.966
A: Edifício Opensat, Lagoa, 4950-283 Mazedo MNÇ, PORTUGAL
It took a few emails to get the language correct, but....
Hi Tim,
Clones ARE NOT available.
Best regards,
Hugo Condessa
court case
Nextorm / DVB World S2101 USB box, software needed pls
