auto shut off feature | Page 2 | SatelliteGuys.US
I could never get the disable to work on my 222 either. Even when you disable it, after the nightly update happens the receiver goes back to the floating DISH logo. I would set an auto timer to fire off in the morning, but that doesn't seem to work any more. I just gave up and decided to forget about it. My 922 DVR is enough for me to manage anyway.
That's great, but the option to disable it should actually work. I can't believe that it's been reported as a bug and they still ship software where the disable function doesn't work. At a minimum they should remove the option from the menu until they fix it.
I just checked my 722 and 211K. Using menu, 8, 4, as Zach has mentioned shows that I have my inactivity standby set to 'disable.' It works, just as it always has.....
722 dvr keeps losing audio
ViP 211K receiver
