AU-9 Assembly Questions | SatelliteGuys.US
cspiteri
385
4
I am assembling my AU-9 Rev. 1 (WNC) dish which came without any assembly instructions. Do the 4 large flat washers go between the nuts and the dish mounting ring or ??? And is the LNB mounting arm installed with the slot (at the LNB end) facing up or down ???
The assembly manual on the solidsignal site is not clear on these details.
THANK YOU!!!
The 4 large flat screws go into the reflector.
The 3 screws with the rounded head go into the base assembly.
Your best bet is to assemble the base 1st, and put the reflector on last.
depends on the brand he will have to remove the tilt plate from the reflector b4 assembling the the whole scew
there are about 11 diferent types of au 9 and au 9t '2
just keep the washers for the lag bolts in the foot and the struts
washers smushers
washers smushers
what?
Local{s} HD Question
TV program guide
