AT9 same alignment as 3 LNB dish? | Page 2 | SatelliteGuys.US
Did you follow all the instructions, rotate the tilt on 119, pull the pin and get symmetrical levels at the stops, etc?
Bob
loudo said:
well, its all set.......took about an hour to align everything just right!
got signals in the 90's on sats 101, 110, 119......i dont have an h20 yet so i cant check the 103, but it should be fine.
just brought my ts360 and a small tv outside and my friend adjusted the dish from there, it was similar to the triple LNB as far as difficulty aligning.
Bob
Doesn't matter since he is not using a H20 and that rotating was bogus.
h20 and the filter...
Thanks Gentlemen for the TiVo!
