My 40" Sony TV's OTA tuner kicks both my Dish & Directv's tuners butt's.... I'm getting 9 channels where with both of those I get 4... KBIM does have guide info, plus I found a PBSHD feed
I would like to know what Dish is going to do to keep from losing hundreds if not thousands if not more subscribers in the Macon, Ga Local area. Most subscribers here got a nasty surprise today when they turned to ABC 16 and Fox 24 to find those channels were no longer on.
Everybody I know that has Dish is pissed and some if not most are planning on calling Directv or Cox Cable to replace Dish.
What incentive is Dish going to provide to keep from losing so many subs? Or is Dish betting that many won't leave or doesn't care if they do?
I'd like to know why Dish doesn't either demand that Tribune give them accurate guide data, or switch to a source that will. See the two threads I started last night titled "guide idiocy alert" for just two examples out of many.
Disputes happen. Its just your turn. How many thousands of Dish subscribers do you really know in the Macon area.
Have you tried deleting the channels in question and then do a manual rescan? When 2 of our stations here changed to VHF, I had to do that to get them back.Also I think I have a contact that used to work in Roswell (where KBIM comes out of) I think he still works for LIN, maybe for KRQE... will see if he can shed any light on my question if the tv's do not have any guide info.
you had to start two thread on the subject?
Exactly... Thanks Tony, I will be at CES and the Dish booth this week so will try to capture some techs there.The 3 stations in SE NM with distance from Carlsbad are:
ABC - 6.1 (19) - KOCT - 28.3 mi. - 40.7 NM @ 35 ft AGL
CBS - 10.1 (10) - KBIM - 51.9 mi. - 39.2 NM @ 35 ft AGL
NBC - 8.1 (8) - KOBR - 73.4 mi. - 12.4 NM @ 35 ft AGL
Back in the analog days ABC and CBS were receivable with a small VHF antenna, but had to have a good one to get NBC without perceptible snow. I presume this means a fringe antenna setup is necessary to get KOBR OTA. It helps that they are VHF channel 8, ABC which is now on RF ch 19 barely reaches downtown Roswell (45 miles) if at all, so , I believe, the owner (KOAT out of Albuquerque) has a LP UHF translator there.
That is one thing I have noticed also... my TV & Directv do the sub channels... KOCT has 7.1 & 7.2(SD spanish), NBC has 8.1 & 8.2 (weather) & none for KBIM... TV only gets NBC & Sub...
Tony, I don't see the relevance of examining the output from a TV ATSC tuner for PSIP program data. There is (or are) approximately ONE Dish Network receiver that uses PSIP data to populate it's guide, rather than the Dish EPG from satellite. I suppose we can find examples of missing PSIP data from a broadcast station. But if it is missing, they're violating regulations, and Tribune (I would guess) do not take their guide from individual stations' real time PSIP data anyhow. So the station's PSIP data is irrelevant to the problem; it all boils down to Tribune data, what Dish is paying for, and technical details.I have not forgotten to keep experimenting with guide information being incomplete and showing "Digital Service". I went home and tried it on a Dynex 40".
Limited time offer
