ASC421 Setup Help | SatelliteGuys.US
ASC421 Setup Help
saidias
70
I have a ASC421 on a Pansat 2700. 1.2M Dish
When I blind scan all the TP polarizations are backwards to Lyngsat.......H are V and V are H. When I mounted the LNB I had the 0 degree pointing upward. Do I have it mounted upside down?
MD
Saidis, you have the LNBF set up 90 degrees off, i did the same thing on my first KU install ;-)
90 degree off.
Okay, So he should turn it clock wise so the zero should be at 3 O'clock.
Or he should turn the 0 counter clock wise so the zero should be on 9 oclock.
I have one of those and I never got it to work.
When I had my ASC421 on my 5' dish, I pointed '0' to the 9 o'clcok position and all was well.
9 vs 3, see what works better for you.
Shawn
Shawn
Thanks Shawn! I will try again this weekend.;)
Adding a satellite to Coolsat 4000
UonTV's current status
