Dishman-n-nc said:My dish
<img src="http://www.satelliteguys.us/attachment.php?attachmentid=82888"/>
Damn birds poop on everything!!!
Sent from my iPhone 4S using SatelliteGuys
You would gain another shot at correctly installing your dish (it sounds like the current install is sub-optimal).Would I gain anything by replacing the current dish with a 1000.2 EA dish for just 61.5 & 72.7? ie: better reception/rain fade/snow/etc.?
The DISH 1000.4 is slightly larger than the DISH 1000.2.Are the two dishes the same size?
You would gain another shot at correctly installing your dish (it sounds like the current install is sub-optimal).The DISH 1000.4 is slightly larger than the DISH 1000.2.
Don't ask me, you're the one that seems to be somewhat disappointed with the performance of your setup.Sub optimal how?
Higher signal strengths are rarely a bad thing but they're unlikely to come from installing a smaller dish (unless your install is sub-par).You wouldn't necessarily gain anything, possibly slightly higher signal strengths.
I can't imagine why you would need to see 119W and how that all figures into the discussion. It doesn't make much difference if you have it hooked to a DISH 1000.4 or a DISH 1000.2 as the documentation that I have indicates that both dishes use LNB assemblies that incorporate DPP43 (wing dish capable) switchgear.If you have a 119 wing dish set up the .2 EA LNB has no input on it so you would need to incorporate a separate switch to keep using it.
Replacing the DISH 1000.4 with a DISH 500 may be a win but that's not what was proposed. The proposal was to replace a three slot dish with a somewhat smaller three slot dish.And yes, the smaller dish will get you higher signals (from my experience installing them) as it's only focusing on 2 orbitals versus the 3 the .4 was picking up.
Apparently they've gone away from the DPP43 in favor of the DPP Twin like the old DISH 1000 had. Sadoun advertises the DPP43 version of the DISH 1000.2.The 1k2 EA LNB (which is new) indeed DOES NOT have an input port on it. Maybe you're confusing the 1k4 EA and 1k2 EA. Or maybe you just need to check your documentation again.
Sure there is. A dish 500 or 500+.......for now at least.
You mentioned a two horn dish and I assumed that you meant a DISH 500. I replaced my DISH 1000 with a DISH 500 and a big wing dish because the DISH 500 gave me better signals than adding the wing dish to the DISH 1000. I wonder how the DISH 500 with a DPP Twin compares with the DISH 1000.2 -- seems like much the same thing except your using a dedicated two-slot dish with the DISH 500 versus a two-slot LNB with a three-slot dish.I don't think at any time did he mention replacing his .4 with a 500 reflector.
Hey speaking of frankendishes.........It's my understanding a 1k4 EA lnb will work on a 500+ reflector. What LNB arm would be the one to use? Or am I mistaken?
The LNB arm/polar plate for the d1k4 will not fit the reflector for the d500+. The top two holes in the d500+ reflector are set higher up than the top two slots in the d1k4 LNB arm/skew plate. I got in a pinch a few years back and ran out of d1k4 reflectors. So I had to do a little surgery on the d500+ reflector with my drill bit. The reflector attached with no issues, and I actually got a much higher signal reading on 77,72, and 61.5.
The d1k4 lnb won't fit on the d500+ LNB arm. Actually the d1k4 yoke will fit on the end, but you have to cut off one of the plastic tabs inside the yoke so it fits flush against the arm. Aside from getting the yoke to fit, the 500+ LNB arm is about 3-4 inches longer than the LNB arm for the d1k4. Those few inches throw off the focal points of the lnb. So the d1k4 lnb won't work properly on the d500+ lnb arm/skew plate.
You can't go wrong with a larger reflector. But when you use a smaller reflector or change the focal point of the lnb's, then you're going to have issues.
Long story short: 1k.2 EA is not worth it over 1k.4 EA if you already have a 1k.4 EA properly peaked.
What's a DPP43? Never heard of it. I know there's the DPP44 and the DPP43, first time I've ever heard of a DPP43.
Limited time offer
