Anyone with TSReader and 91W circular DBS...need a quick favor | SatelliteGuys.US
digiblur
14,190
4
Louisiana
If you have TSReader and circular 91W abilities...please send me a PM. I need to grab some snapshot files from you until I can figure out my satellite tuner issues.
Here's about 1 MB of PIDS 16 and 17 from 91° West 12297 L/H
(I think that's what you are looking for, but if I am wrong let me know.)
Close... here's the command line:
TSReader -y 30 -H+18 c:\myfolder\bell-2010-02-22_1950.htm 12224 V 20000 0 0 5 4
of course you can change the filename and folder to what you want.
The last digit is the DiseqC switch port. NOTE: it is case sensitive.
"Note: it is case sensitive "
I assume you mean the whole command line is case sensitive. :) I spent a few seconds trying to figure out what a lower case 4 looks like compared to an upper case 4. Well, I haven't had my first coffee yet ! :)
The command line didn't work for my source (I think there are some slight differences depending upon what card is in use), but rather than trying to figure out what needs changing, I just tuned in the 12224 mux, and waited until all the SDT stuff loaded, then did an export. Hope this has what you need.
http://www.eskerridge.com/bj/sat/n1-91-12224.htm
Yeah... I guess I should have said the command line is case sensitive ;)
Looking for a Captain 8000HD manual
Anybody own a CS 7100 Micro PVR rec?
