Anyone Else Missing Some HD Channels?? | SatelliteGuys.US
nickg420
788
179
Flowery Branch, Ga
I woke up this morning to NO TNT-HD and no HDNet Movies in my channel lineup.....My wife says it hasn't been there for a couple of days anyone else having this issue or know something I don't???
I had both just fine last night. Might want to check your channels you receive list and make sure they are in there. If not then unplug your receiver, wait 30 seconds, then plug back in. Should reaquire the sat info and you should be ok.
I also have this channel that simply says HD the guide info says upcoming Braves vs Marlins does this mean I may finally get my braves games in HD???
Maybe... If you are not in the ATL market then you should get it on channel 95.
No issues here.
You will only get the HD feeds if your zip code was included in the database that the team/league sent to DirecTV per market. many HD areas have been somewhat smaller than the same SD area; so your milage may vary.
I keep tabs on HD sports here: http://www.hdsportsguide.com/
DirecTV HD DVR Delayed Again
Order D* HD Now or Wait Until "Fall"?
