You have to press Info button first then the Recall button.
My bad. I had paused the program earlier for a pee. It works as you said when done live. Thanks for the tip.
Why not keep the 622 as your primary receiver, use Tv2 for the kitchen and upgrade the other Tv's to Wally's with external hard drives
I didn't think you could add a Wally to an account that has a ViP.
On this, I agree with you. Dish's rules concerning mixing receivers is ridiculous. With 1 DPP LNB, a 42 Switch and a 44 Switch, you could run a myriad of setups. Hopper Sling with 2 Hopper 3's and up to 14 Joeys, plus a VIP or Wally off the 4th output of the 44 Switch. Or 2 Hopper 3's off the 42 Switch and 4 VIP's/Wallys off the 44 Switch. Or trunk in a 2nd 44 switch. I've always believed that if you can imagine it, you can do it.You might be right. Another stupid dish rule.
Could do a 211
That works!
It works on my Hopper 3 and 4k Joey. Make sure you are viewing live TV.Tried it on my setup. Did NOT work on the Hopper3 but DID work on the Joey3. My Wally is currently not enabled so I'll rely on others there.
Limited time offer
