Why not just put the converter box in front of the 522? The signal from the box will be analog on either channel 3 or 4.
Any of those things have UHF remotes?
Doubtful. But you could always add one of those internal RF remote adapters.Any of those things have UHF remotes?
My DMA has 2 CBS, 2 NBC, 2 ABC, 2 FOX and 2 PBS stations. They simucast (sp) stuff but each station (with the exception of PBS) offers their own local newscasts. Currently Dish carries ONE ABC, NBC and PBS in my DMA and each of them is from the far city, none are the "local" newscasts. Thanks for your help tough!
No your DMA does not have 2 each of these channels. None do with the exception of PBS. You may be near the boundary of 2 DMA's and can pick up both with an OTA antenna, cable or a combination of the 2. Cable is allowed to deliver more than one DMA but satellite is not except in the case of the distant networks rules that Dish is not allowed to do. Thats a whole nuther story.
Since they did it on purpose ahead of the cutoff date, expected behavior. I would expect dish will change their uplink to use the digital feed sometime between now and then.There is one local channel I can't get with an OTA without screwing up all the others so I watch that one via sat. They did a demo this morning to show what will happen and if you will need a converter or not. They pulled the analog plug for about 15 seconds and a message appears that says if you see this you need a converter box. I thought signals coming from the sat. were all digital and Id have no problem but I guess I was wrong. They've been saying if you have cable or satellite your fine but this demo proved that wrong.
Their demo is wrong. In many cities, the satellite companies currently use the analog signal to obtain their locals over satellite. Dish just started installing digital receivers to replace their analog equipment. Later this year, Dish will complete the equipment changeover and then the demo will be correct for satellite customers. When they change, you will see improved picture quality on SD locals, HD locals are already using the digital signal.There is one local channel I can't get with an OTA without screwing up all the others so I watch that one via sat. They did a demo this morning to show what will happen and if you will need a converter or not. They pulled the analog plug for about 15 seconds and a message appears that says if you see this you need a converter box. I thought signals coming from the sat. were all digital and Id have no problem but I guess I was wrong. They've been saying if you have cable or satellite your fine but this demo proved that wrong.
Limited time offer
