Try connecting only to a KU LNBF. Take the switches and multiple LNBFs out of line for testing.
Right now it appears that you may be powering both LNBFs and definitely both KU polarities at all times. This would account for the exceptionally high current draw displayed on your meter. If you continue to use a multi-switch for the KU LNBF, you best use a powered multi-switch instead of a passive version that requires quite a bit of power from any device.
The motor and LNBFs should present load value of approximately 75 ohms. Not sure why it is dropping to below 25 ohms. Likely the multi-switch is the cause, but it would need to be by-passed to test.
I really do not think that this problem is related to barrels or ground blocks.The Primestar LNBF is a great performer, but it is a power hog!
You just slide the battery cover off and put the Lanyard Loop over that Tab and slide the Cover back on !Hello Guys and ladies
I been trying to remove the back of the remote to install the strap that comes for the remote, has anybody been able to remove it? this thing just does not come off, what is the the best way so no damage is done.
Regards.
Tunder
Did you change the switch configuration and add the power inserter as we discussed? I would expect continued problems with the set-up's high current draw that far exceeds any STB. Something is definitely wrong when the resistance drops to 23ohms and the current consumption skyrockets.
That was a problem I learned early on in my (never ending) learning days. So when I make connections I always make the copper center wire a little longer than normal.
If you have the coax center conductor protruding out more than 1/8" inch you are not making professional connectors.
Likely with that extraordinary current draw and a DiSEqC 1.2 motor to boot, the ASC1 will display "Over Current" and go into protection mode. There is something wrong out at the dish farm. Bad multi-switch? Bad LNB?
If AC power at the inserter is not an option, then it might be best to swap the passive multi-switch to a powered multi-switch that has the AC adapter inside and the DC runs through a regular dedicated coax run to the multi-switch.
I'm not a professional, just a hard headed hobbyist that's too dumb to know when to quit.
Here's the length I make my wires to. I bought all the proper tools so it strips the wire to the same length every time.
Example: (I can't translate decimals to fractions so I don't know if this qualifies or not but the mm button on the gauge says 5mm if that matters)
Limited time offer
