AMC-3 C-Band (4080H) DVB-S2 on a 4' Dish | Page 3 | SatelliteGuys.US
After having this setup now for the past several weeks, I believe I'm going to disassemble it and return to having a KU LNBF centered and a C LNBF off to the side (http://www.satelliteguys.us/248937-two-c-band-lnbfs-3.html).
While the centered C LNBF worked very well and provided awesome DVB-S2 signal quality I found that the tracking was off on some satellites as I searched the satellite arc. For example when I went to AMC 3 it was always dead on, but when I turned to Anik-F3 for TV Hot or to Galaxy 17 I always had to bump the motor a notch or two to get back the signal.
Due to rain, I didn't get to work on this project. Instead, my wife and I setup our new Casper mattress. I'm going to sleep good tonight.
I opened the Titanium C1-PLL C-band LNBF and all I can say is "WOW". Certainly a very well designed and built product. I'm thinking about upgrading all my other C-Band LNBFs to this model if it performs as well as it looks.
Reactions: Titanium
The setup:
  • Channel Master 1.2m Motorized Dish
  • PLL KU LNBF
  • Titanium Satellite C1-PLL C-Band LNBF
  • Conical Scalar
  • 3 Feed Support Arms w/ Custom Brackets
  • Ecoda 0/22 KHz Switch
  • RG-6 Quad Shield Coax Cables
While I was out installing this setup, some young guy stopped and asked if I had any extra large satellite dishes that he could use as shields when playing paintball. :eeek
Starting tomorrow, I'll begin to post the results of the C and KU transponders and satellites received with this setup.
It's real "purdy", but I predict it will soon be disassembled in order to optimize for C-band reception. :(
The feehorn fore/aft position and conical scalar position (in tandem) are both highly critical to receive C-band on a small reflector. I usually will first rough in the reception using the feedhorn only. Slide fore/aft and skew left/right to optimize. Once a signal is locked, then add the conical scalar and slide only it fore/aft and rotate to optimize. Then slide the feedhorn/conical combo fore/aft and slight rotation to optimize, then slide only the conical fore/aft/rotate, then the combo fore/aft/rotate, then the conical, then the combo..... you get the picture! Once you think the signal is optimized, change to a different transponder. Don't be surprised if the feedhorn and scalar placement might need to be changed to optimize. Even panning the feedhorn up/down/left right (aiming into the dish can increase the Signal Quality.
Rejection of interfering signals from terrestrial and adjacent satellite will optimizing the desired signal. It is a balance between optimization on diferent transponders and satellites to get the channels that you really want....
Reactions: PopcornNMore
Performed some scans last night without doing any adjustments. A nice selection of channels scanned in having a signal strength over 45%. A new religious channel on Galaxy 19 scanned in having a signal strength of 89%. Just some of the channels are FOX, NBC, COZI and THIS on Galaxy 16, AMG-TV, Dr. TV, LATV and The Walk TV on Galaxy 19, PBS HD and SD on SES3 and a few other channels. Granted, I didn't scan the entire arc or even adjusted the azimuth settings using the motor. Just a quick search when commercials were on during WWE RAW last night.
Too bad you're not selling those bent brackets for the CM/Andrew dishes. You could probably make some money.
Funny you said that, because I was thinking of this just today. :) I started Rinker Technologies about six months ago and was thinking about adding these brackets as a new product. I would also love to offer my customers the Titanium Satellite C-Band C1 and C2 PLL LNBFs, because its such a great product that I highly recommend.
EchoHorizonMount Usals mod
C band dish install question.
