The one I listen to comes from Valdosta GA on 88.5 and although not often, yes, they've played Chevelle. But they might not be using the sat feed all the time either....
I heard POD on there the other day and I thought the Sirius was on.Air1 plays Chevelle? They usually sound way too much like KLOVE for my tastes...strange since they're owned by the same people.
I'm 99% sure Refuge Radio is up there....somewhere on Ku. As Christian music goes, it's far more upbeat and diverse -- especially at night.
Cool..I see that K-Love is active. Air-1 is my favorite 'cause they play more rock like Flyleaf, Chevelle and P.O.D. but I like K-Love too.Thanks, Iceberg!:up
The KU side of AMC1 is off by 25-26 degrees. So for me in Minneapolis to get "optimum" signal on there I have to skew the LNB as if I was on SBS6/H2. The C-Band side is fine. As noted above, it is that way and we have had been that way since day 1.
I remember an uplinker telling us that...let me find it
edit: found it
http://www.satelliteguys.us/1047803-post17.html
Some of the stronger signals work fine even with the "offset" offset (ie: the skew being what would be considered normal) but the news feeds you have to skew the LNB differently to get them all...mainly because they run at lower power to begin with so
lower power + skew messed up on dish = no or little quality
yep they are there...just checked...ones in BOLD are active...69 quality on Coolsat with "normal" skew (normal as in on a motor)
11804 V 3500
you have to scroll through the language/audio pids but they are there. Matched them up with global-cm.net list
8191 0036 Audio: 2 God's Country Radio Gospel/Country
8191 0037 Audio: 8 Air-1 Radio Contemporary Christian Music
8191 0038 Audio: 3 K-Love Radio Contemporary Christian Music
8191 0039 Audio: 4 K-Love Radio Contemporary Christian Music
8191 0040 Audio: 6 Air-1 Radio Contemporary Christian Music
8191 0041 Audio: 9 K-Love Radio Contemporary Christian Music
8191 0043 Audio: 5 Air-1 Radio Contemporary Christian Music
8191 0044 Audio: 7 Spare audio channel
8191 0045 Audio: 1 K-Love Radio Contemporary Christian Music
Thanks! This has helped me to decide. Would a 36" dish be what I would need? And any specific receiver?
An old co-worker is the manager up at The Refuge now, and she loves it. They'd like to get into the Cities, but that's a huge hurdle with money and space and the usual. I need to ask her about their uplink the next time I see her![]()
yes the weaker signals will come in betterIce,
OK, so I am probably not scanning in all of the active feed channels because I have not compensated for this. The stronger signals are coming in ok, but could possibly be improved if I were to play with the skew (polarity of the LNBF)?
yes. You have to play with it a little bit to find optimum quality. But yes its set about to what it would be for H2.Which direction should the LNBF be skewed if I am standing in front (south) of the dish? CW or CCW? I would assume CW since you state that it is akin to polarizing it for H2. Am I correct?
I will try this in the next few days if it is nice and warm and clear skies. I won't be able to leave it set there as this is on my motorized dish and would mess up the other sats. However, I am curious.
Thanks Ice and B.J.
Radar
A 36" would be great. Some folks here report excellent results with the Winegard .76 cm as well.
For receiving radio signals almost any receiver should work. I'd recommend getting a Fortec Star, Traxxis or a Coolsat. Many of which can be purchased new or second hand.
Try to support the sponsors listed above. You don't mention where you live. In order to get the best shipping rates try to pick someone closest to your location. For example, Sadoun is in Ohio and SatelliteAV is in California. Mike Kohl at global communications can set you up if you are near Wisconsin.
There is one other dealer worth mentioning although I have not purchased anything from him. Perhaps someone can comment on Taylor Enterprises Satelite Unusual Taylor Enterprises MPEG2fta Digital Receivers They have a sweet deal on a Traxis 3500, Winegard .76cm dish and LNBF provided the shipping isn't too much. Seem like a perfect setup for FTA satellite radio.
My location is outside of Nashville, TN. I also would like to get RTN, which I gather is another issue with signal strength. I would need a motor to change satellites.
Limited time offer
