Alternatives to this remote?? | SatelliteGuys.US
Pro Lex Performance
4
Hi,
Is there any alternatives to this remote? I have tried reprogramming my reote for the panny th50px20, I think it is 108 but I cannot get the action/enter button to work. Any ideas?
-Mike
I'm using a Home Theater Master MX-500 and I like it a lot. I just had it learn all of the Voom remote commands I wanted to use.
Have you considered a universal remote? The Harmony H659, URC-200, and MX-700 are all popular universal remotes. There is a forum thread on remotes right here.
I like the MX-700, but bought the one on the right (below) for my parents, who just got VOOM.
Everything I own (but the moto box) is Sony so I use the Sony RM-AV3000. It learns so it's pretty easy to transfer over the buttons and I'm pleased with the results.
Pronto is good also if you are a Tweak Meister, otherwise it has a very steep learning curve. It is totally customizable and has an extremely strong IR blaster with a wide field of range.
Dvdo Video Scaler
when are the new dishes supposed to be installed?
