All 103b Lit Up !! | SatelliteGuys.US
All 103b Lit Up !!
Okay, Im waiting here, watching transponders and checking future HD channels every five minutes. I think its safe to say, I NEED MEDICAL HELP!!! :D
Whats sad is, you will probably get more enjoyment over checking the signal strength every 5 minutes then you will get from the new HD channels when they do launch. :D
As Scott mentioned ... well probably all keep checking to see if they are on and once they are, we'll come back to the computer and report .... and fail to spend anytime watching them.
btw, thats GOOD for Scott !!!
Jimbo
OK are the HD channels activated about 24.25 hours from now? Or anytime on Wed, what's the deal? Do any of you "spies" know? I have a couple of SS of 94 most around 95%. TRPR's 17 & 22 I'm getting 100% SS, SE NC
Should I be worried if I'm not getting a signal (at all, 0%) on 103b?
Edit: I take that back, now they're all 85+ except for the ones that say N/a
As testing is going on, are the transponders going on & off? I checked signal strenght last night and was getting nothing. I'll check again tonight.
I am in the Richmond, VA area, have a 5 lnb slimline and 2 H20 receivers.
I get a high 80's - low 90's signal on the 3 existing sats.
HD Spot beam cutoff time
NFL Sunday Ticket player tracker...anyone use it?
