Aiming | SatelliteGuys.US
Aiming
pitmonkey29
29
I got a complete dish that was setup about 5 minutes away from the city limits on the Southside of town.when I go to set the dish up will be much difference in the setup or should I be able to aim the pivot true north
Are you talking about a C-Band dish?
Either way, if there pole was true plumb and your is also, it should not be hard to set-up. If it was still set-up properly you will not have to touch the declination, if this is a C-Band Dish.
Your declination angle should be the same. Just get the polar axis set by rotating the whole assembly so it tracks the entire arc properly. There's a lot of info on how to find true south etc on this forum.
And ty u all for the help
True south, if you're in the northern hemisphere. Do you know what size/kind of dish it is?
Black mesh 10 or 12 ft with us us electronics gold lnb and feed horn
How to slave a receiver
4dtv sound dropouts
