Aim with unactivated receiver | SatelliteGuys.US
javier911
19
I was doing this by hitting sysinfo button a few times and then cancelling out of that and hittig MENU on the remote. I let the receiver update to latest software and that trick doesn't seem to work now.
It's a 211, anyone know how I can get into the menus now?
If you are trying to see what your signal strenght is you need to press menu 6, 1, 1. From there you can do a check switch.
Remote Access
722 DVR
