Adding SATs in Coolsat 4000 Pro. | SatelliteGuys.US
dvdmkr
23
I have Coolsat Pro 4000
The Coolsat came with pre-programmed SATs in the receiver.
I would like to add some SATs those are not already in Coolsat.
Like, Atlantic Bird 1 @ 12.5W, or PAS 1R @ 45W, etc...
Could someone tell me how to add it??
I could not find anything about adding SAT from manual.
Thanks!
In dish setup just shuffle to a blank satellite slot and re-name it. You can also do this on sat locations you won't use (I used to do this on the C-band locations). There are quite a few available slots, even if you keep all the c-band stuff in tact.
I just edited mine to include all sats from PAS9 (58w) though Echo 1/2 (148w) Ku & Cband and I have around a half dozen sat locations left.
It's a LOT faster to do this with a channel editor such as NDFEdit.
Xtreme 0.3db LNBF (NEW)
Intelsat 805 on 120cm Cband?
