Adding more lines for more receivers | SatelliteGuys.US
you need one line from the switch for each receiver. If it's a dual-tuner and your switch is not a DPP44 and your LNBF is not a DPPTwin, you need two lines.
For all versions of the Twin and Quad, the switch is in the assembly with the 2 LNBs. The DP21, DP34, DPP44 and legacy SW## switches are external and can be mounted either at the dish or at a central distribution point.
The EKB Switch Selector will show you many options for connecting 3 receivers.
322 dead
Any More HD Locals Coming And When...?
