Did you do a check switch before you started moving the dish?Carried my generator, box and tv down this afternoon and tried pointing the dish.
I covered the two outer lnb and found 72 with about 55 strength. Uncovered the lnb and had 0 for the others. I tried moving slightly left and right but any movement over probably 2 degrees dropped my 72 down in the 20's.
What am I doing wrong
Just get the aiming correct......Thanks brussam, so you saying with what I have now I should get all the satellites if I point it correctly, I don't need any thing else.
I agree, Dish receivers are a Pain to use for setting up a satellite Dish.View attachment 119700 View attachment 119701 I drove back down this afternoon when we got back from the lake. I was still only able to find 72. It peaked at 60. I ran check switch and that's all that showed up. On the dish pointer screen if I change it to 61.5 all I get is wrong sat.
Well sort of, The 72 would show up in the first box if he's only receiving the 72.Not 100% sure but I believe 77 should be in the first satellite box. I f indeed this is the case you are receiving 72 on the 77 portion of the lnb which means you are 5 degrees off on you aiming.
Hopefully others with a 1000.4 ea dish will chime in.
Good part is most channels are on 72.![]()
Never seen a receiver setup. The Switch Check sets the receiver to what ever you are pointed at.But my other question, Was the receiver brand new?
Because I would think it would have already been setup for 61.5 and 72.
Unless it was western arc.
Correct, but the previous setting should have been preloaded in the 211 from the previous owner.Never seen a receiver setup. The Switch Check sets the receiver to what ever you are pointed at.
This is exactly what Im wondering...Did you do a check switch before you started moving the dish?
Yes you can TWEAK it probably slight elevation adjustment..Well third trip was a charm, I covered the two outer lnb found the 72 and then removed the foil and had 61.5. No 77 but I didn't notice any channels on it. The 72 was around 49 strength and 61.5 around 45.. I imagine I could tweet it and do better.
Thanks for all the help. We just got set up for the long weekend
Yes good, nothing on 77 to worry about, but you could try peaking what you have.Well third trip was a charm, I covered the two outer lnb found the 72 and then removed the foil and had 61.5. No 77 but I didn't notice any channels on it. The 72 was around 49 strength and 61.5 around 45.. I imagine I could tweet it and do better.
Limited time offer
